dnplas
(Daniela Plascencia)
1
Hi folks!
I’d like guardrails for charms owned by the Kubeflow team (lp: ~kubeflow-charmers).
For the following charms, we need \d.\d+ guardrails (e.g. 1.20):
- kfp-persistence
- kubeflow-roles
For the following charms we follow a ckf-major.minor format (e.g. ckf-1.8), so we need guardrails that allow us to do so. Perhaps ckf-\d+?
Thanks in advanced!
Hi,
Before proceeding, for the first guardrails (ie 1.20), would \d\.\d+ be a better fit (the . is escaped)?
And for the second guardrails (ie ckf-1.8), the given regex wouldn’t match the example. Does ckf-\d\.\d+ seem suitable?
Thanks,
Deep
dnplas
3
Thanks @superalpaca I am okay with both suggestions.
I’ve added the requested guardrails to the charms above.
Thanks,
Deep
