Hi,
Please could you change the consul-client charm’s ownership to the group openstack-charmers ?
Also can you create guardrail \d\.\d+ (versioning is x.yy )
Thank you, Hemanth
Hi,
Thank you, Hemanth
Hi, @hemanth-n!
Your regexp for guardrail is not strict and will allow versions like 1.100000, is this OK? I could set something like \d\.\d{2}
One more question to clarify - is this OK for your team to transfer charms without stable version?
Hi @drednout
Thanks for pointing the correct regex. Yes transferring charm to the team is OK without stable version.
Also could you please change the regex for consul-k8s to \d.\d{2}. (It is \d.\d+ earlier)
Thanks!
Hello, @hemanth-n !
I’ve set the requested guardrail \d\.\d{2} for consul-client charm. Also ownership was transferred to openstack-charmers publisher.
Enjoy your day!
consul-k8sto \d.\d{2}. (It is\d.\d+earlier)
Do you mean \d\.\d{2} or do you need to have not only “.” symbol in your tracks for consul-k8s?
My bad, without dot. So it should be \d\.\d{2}
Hi again, @hemanth-n !
We’ve just updated the guardrail pattern for consul-k8s charm, now it looks like:
"guardrail_patterns": [
"pattern": "\\d\\.\\d{2}",
"created_at": "2024-10-09T15:43:03.895134"
Have a nice day!
