Request: Change ownership of charm
Hi!
Could you please change the ownership of the bind charm to the IS DevOps team
The charm is registered but for some reason it doesn’t show up in charmhub.
Thanks in advance!
Hi,
The ownership has been updated as requested. As discussed offline, the proper way to make your charm findable is to follow the process of listing (example). Then, and as long as you have published a stable revision, your charm should show up.
Thanks,
Odysseus
