Hello,
Please could you add the 3 tack from the charm-mongodb.
Thanks.
Hello,
Thanks.
Hi, I’ve added the 3 track for mongodb.
After a conversation with the data platform team, we agreed that track 3.6 will be used instead of 3. Can I ask you to create 3.6 and delete 3? I apologize for the trouble. Thanks Robert
Did you publish anything with the 3 track? If you did, I can’t delete it. Let me know.
3.6 is now created, regardless.
Yes, I already published 3/edge. Is there way how we can remove it?
We closed the 3/edge so now it could be removed.
Hi,
No, sorry - once something has been published to a track, it can’t be deleted.
The recommended thing to do is to close the track (which is what you did), but strictly speaking the track still exists. Just ignore it
If it’s closed nobody can see it.
