A Kubernetes charm that checks if a GitHub repository aligns with a chosen set of policies for workflow runs.
When using the github-runner charm to deploy and manage your self-hosted runners in OpenStack mode,
the self-hosted runners can execute arbitrary code. This may hurt compliance. Deploying the
repo-policy-compliance charm and exposing it to the github-runner charm ensures that only authorized
code is executed, and so your GitHub repository remains compliant.
For more information, read the GitHub runner charm documentation.
Like any Juju charm, this charm supports one-line deployment, configuration, integration, scaling, and
more. For the repo-policy-compliance charm, this includes the ability to:
- Customize enabled policies.
- Run in debug mode.
- Choose different GitHub authentication methods.
- Modify Flask-specific features like a secret key for security-related needs, the run environment (e.g., production) or where the application is mounted.
See the Actions and Configurations tabs to learn more about the actions and configurations supported by this charm.
Contents
Policies
The charm exposes several functions to check for compliance with the following policies:
target_branch_protection: That the branch targeted by a pull request has protection enabled and that rules cannot be bypassed. The requirement for reviews is relaxed for non-default branches where both the source and target branch are on the repository.collaborators: That all outside collaborators of the project have at mostreadpermissions.execute_job: That a user with write permission or above has left the comment/canonical/self-hosted-runners/run-workflows <commit SHA>approving a workflow run for a specific commit SHA. Only applicable to forked source branches.disallow_fork: That the source branch of a pull request is not coming from a fork. Still permits forks coming from collaborators having write permission or above.
Furthermore, Repo Policy Compliance provides the following endpoints to check the above policies for GitHub events:
pull_request: If the configuration option is enabled, runsdisallow_fork. Otherwise runstarget_branch_protection,collaboratorsandexecute_job.workflow_dispatch: Runscollaborators.push: Runscollaborators.schedule: Runscollaborators.
Get started
This section provides a brief overview on deploying, configuring and integrating the
repo-policy-compliance charm for basic usage.
Requirements
- A Kubernetes cloud.
- Juju 3 installed and a controller created. You can accomplish this process by using a Multipass VM as outlined in this guide: Juju | Manage your deployment environment.
- A GitHub repository (formatted as
OWNER/REPO) for which you want to check compliance. - A GitHub Personal Access Token with repository scope.
Set up
Create a Juju model:
juju add-model prod-repo-policy-compliance
Deploy
Deploy the repo-policy-compliance charm as the repo-policy application, configuring at the same time its charm token and GitHub token:
juju deploy repo-policy-compliance repo-policy --config charm_token=abc --config github_token="github_pat_foobar" --channel latest/stable
PostgreSQL is required in order to use Repo Policy Compliance. Deploy the postgresql-k8s charm:
juju deploy postgresql-k8s --trust
NOTE: For
repo-policy-complianceto work, you must set thecharm_tokenandgithub_tokenconfigurations. Thecharm_tokenis chosen by you and must be shared with the authenticating client to generate one-time token authentication. Thegithub_tokenis either a GitHub Personal Access Token (with repo scope) or a fine-grained token with read permission for Administration. Read more about allowed GitHub authentication methods in the Reference document.
Integrate PostgreSQL and Repo Policy Compliance:
juju integrate postgresql-k8s repo-policy
Monitor the status:
juju status --watch 1s
Wait for both applications to reach an active idle state. The output should look similar to the following:
repo-policy microk8s microk8s/localhost 3.1.8 unsupported 12:21:02+02:00
postgresql-k8s 14.12 active 1 postgresql-k8s 14/edge 272 10.152.183.64 no Primary
repo-policy active 1 repo-policy-compliance latest/edge 66 10.152.183.139 no
postgresql-k8s/0* active idle 10.1.72.161 Primary
repo-policy/0* active idle 10.1.72.167
Note the IP address of the repo-policy/0 unit; in the example output above, 10.1.72.167 is the necessary IP address.
Use Ctrl + C to exit.
Generate an authentication token and test
Now generate a one-time authentication token for Repo Policy Compliance using curl and save it as the ONE_TIME_TOKEN environment variable. You will need the IP address of the repo-policy/0 unit (in this example, 10.1.72.167). You will also need the token used for charm_token configuration (in this example, “abc”).
ONE_TIME_TOKEN=$(curl http://10.1.72.167:8000/one-time-token -H"Authorization: Bearer abc" )
The variable should look similar to the following:
d156dda1f03df9d42fd788d93799c57b4275ca5facccce92ef9b91cf4fc13f6a%
Finally, use the repo-policy-compliance unit IP address and the one-time token to check for compliance on a GitHub repository formatted as OWNER/REPO.
curl -i http://10.1.72.167:8000/push/check-run -H"Authorization: Bearer $ONE_TIME_TOKEN" --data '{"repository_name": "OWNER/REPO"}' -H"Content-Type: application/json"
HTTP/1.1 204 NO CONTENT
Server: gunicorn
Date: Wed, 11 Sep 2024 12:09:11 GMT
Connection: close
Content-Type: text/html; charset=utf-8
The 204 status code indicates that the repository is compliant.
Integrations
The repo-policy-compliance charm requires a PostgreSQL integration over the postgresql_client interface.
To make this charm accessible from outside the Kubernetes cluster, integrate with an ingress charm (for instance, nginx-ingress-integrator).
To integrate this charm with the github-runner charm, the integration is not handled by Juju. In the GitHub runner charm, you create the integration to repo-policy-compliance by setting the configuration options repo-policy-compliance-url and repo-policy-compliance-token for the URL and token respectively. See the GitHub runner charm documentation for more details.
All other supported integrations are with the Canonical Observability Stack. See the Integrations tab for more details.
See also
- GitHub repository: repo-policy-compliance
- GitHub runner charm documentation
Project and community
The repo-policy-compliance charm is a member of the Ubuntu family. It’s an open-source project that warmly welcomes community projects, contributions, suggestions, fixes, and constructive feedback.
License
Repo Policy Compliance Documentation Copyright 2025 Canonical Ltd.
This work is licensed under the Creative Commons Attribution-Share Alike 3.0 Unported License. To view a copy of this license, visit http://creativecommons.org/licenses/by-sa/3.0/ or send a letter to Creative Commons, 171 Second Street, Suite 300, San Francisco, California, 94105, USA.
Navigation
| Level | Path | Navlink |
| 1 | reference | Reference |
| 2 | reference-github-auth | GitHub Authentication |
| 1 | explanation | Explanation |
| 2 | explanation-charm-architecture | Charm Architecture |
