Hi,
I’ve been trying to replace EasyRSA with Vault on Charmed Kubernetes v1.19 following the guide - Transitioning an existing cluster from EasyRSA to Vault . I’ve configured Vault as an Intermediate CA signed by a self signed Root CA.
- After removing the EasyRSA charm, and restarting the kubeapi-lb, it’s in error state with the following error log:
2021-08-29 16:33:58 WARNING start Traceback (most recent call last): 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/charm/hooks/start", line 22, in <module> 2021-08-29 16:33:58 WARNING start main() 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/.venv/lib/python3.6/site-packages/charms/reactive/__init__.py", line 74, in main 2021-08-29 16:33:58 WARNING start bus.dispatch(restricted=restricted_mode) 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/.venv/lib/python3.6/site-packages/charms/reactive/bus.py", line 390, in dispatch 2021-08-29 16:33:58 WARNING start _invoke(other_handlers) 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/.venv/lib/python3.6/site-packages/charms/reactive/bus.py", line 359, in _invoke 2021-08-29 16:33:58 WARNING start handler.invoke() 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/.venv/lib/python3.6/site-packages/charms/reactive/bus.py", line 181, in invoke 2021-08-29 16:33:58 WARNING start self._action(*args) 2021-08-29 16:33:58 WARNING start File "/var/lib/juju/agents/unit-kubeapi-load-balancer-0/charm/reactive/tls_client.py", line 51, in store_server 2021-08-29 16:33:58 WARNING start server_cert = server_cert + '\n' + chain 2021-08-29 16:33:58 WARNING start TypeError: unsupported operand type(s) for +: 'NoneType' and 'str' 2021-08-29 16:33:58 ERROR juju.worker.uniter.operation runhook.go:139 hook "start" (via explicit, bespoke hook script) failed: exit status 1 2021-08-29 16:33:58 INFO juju.worker.uniter resolver.go:143 awaiting error resolution for "start" hook
When I print the server_cert, server_key and chain from store_server(), I get empty values for the first two:
2021-08-29 16:59:21 INFO juju-log Server Certificate: None
2021-08-29 16:59:21 INFO juju-log Server Key: None
2021-08-29 17:00:28 INFO juju-log Chain Certificate: -----BEGIN CERTIFICATE----- -----END CERTIFICATE-----
- Also, the client returns the unknown CA error although I’ve installed the CA cert on all nodes:
$ kubectl get all Unable to connect to the server: x509: certificate signed by unknown authority
Would be grateful for any suggestions on how I should resolve this?
Thanks & Regards, Sana
