Originally posted here
TLDR: Almost[1] all of the actual charm tests have been removed from Zaza and moved to a new package in the openstack-charmers namespace: zaza-openstack-tests. This new package is named zaza.openstack for reasons which I will discuss below!
[1]: Almost, because we made the decision that there may be shared, generic tests that could live in Zaza. Currently, the only included test / configure step is the NoOp ones, allowing functional validation of a Zaza test configuration, as is used in the Zaza functional test gate.
Historically, Zaza has contained a fairly strong legacy showing itβs roots in the OpenStack Charms team, as we developed a testing framework to fit our needs. As Zaza has matured, it has become possible for it to be much more broadly useful; however, the OpenStack legacy means that there are a lot of OpenStack specific bits in the core library! For some time now, it has been one of our goals to take advantage of features that Zaza has grown to split the test framework and the OpenStack Charms test implementations into separate libraries, and we have recently done most of that work!
Why is the new package zaza.openstack?
As a part of this work to split out the OpenStack specific tests, we decided to remodel Zaza with a nice namespacing. There are now only a couple of root targets in the Zaza package, zaza.charm_lifecycle, zaza.charm_tests, zaza.utilities, zaza.controller, and zaza.model. This core package should stay fairly stable at this point.
What this reworking allows is for other projects, if they wish, to namespace their tests inside the zaza namespace as well. For example, I could write an Elk Stack series of tests, which may be generally useful to the different components. I could then create my zaza.elk package, and embed all of my tests in there! This would allow you to share your common tests as a normal Python package and reference your tests in the tests.yaml within the zaza namespace, such as:
tests:
- zaza.elk.validate_elasticsearch_is_listening
- zaza.elk.test_read_write_elasticsearch
configure:
- zaza.elk.configure_elasticsearch
Of course, this functionality is not meant to restrict test authors in any way! If you would rather write your tests into a package named my_awesome_elk_tests, and reference the above tests as my_awesome_elk_tests.test_read_write_elasticsearch, be my guest!
How can I use the OpenStack bits in my tests?
If you are already using some of the OpenStack charm tests or configuration bits in your Zaza tests, there will be a couple of changes youβll need to make!
First, youβll need to ensure that you pull in the new zaza.openstack package in your virtualenv. An example test-requirements.txt that we use in the openstack-charms:
git+https://github.com/openstack-charmers/zaza.git#egg=zaza
+ git+https://github.com/openstack-charmers/zaza-openstack-charms.git#egg=zaza.openstack
Additionally, youβll need to make some changes to your tests.yaml:
configure:
- - zaza.charm_tests.glance.setup.add_lts_image
+ - zaza.openstack.charm_tests.glance.setup.add_lts_image
- - zaza.charm_tests.nova.setup.create_flavors
+ - zaza.openstack.charm_tests.nova.setup.create_flavors
tests:
- - zaza.charm_tests.ceph.tests.CephTest
+ - zaza.openstack.charm_tests.ceph.tests.CephTest
How should I write my own library?
If you want to start writing your own shared Zaza library, I have a few suggestions from structuring zaza.openstack! First, a basic look at the suggested directory structure of a Zaza library:
βββ copyright
βββ doc
β βββ source
β βββ generic-utils.rst
βββ LICENSE
βββ README.md
βββ requirements.txt
βββ setup.cfg
βββ setup.py
βββ tox.ini
βββ unit_tests
β βββ __init__.py
β βββ utilities
β β βββ __init__.py
β β βββ test_zaza_utilities_generic.py
β βββ utils.py
βββ zaza
βββ __init__.py
βββ my_package
β βββ charm_tests
β β βββ my_service
β β β βββ configure.py
β β β βββ __init__.py
β β β βββ test.py
β β β βββ tests.py
β β βββ test_utils.py
β βββ configure
β β βββ my_thing.py
β β βββ __init__.py
β βββ __init__.py
β βββ utilities
β βββ generic.py
β βββ __init__.py
Most of these will be fairly self-explanatory as a python package, the important bits are the zaza/my_package directory, as that is where your test code will live! As a fan of all kinds of testing, I also suggest including as much unit testing of your code as possible. If you have shared utilities, add tests for those! In the above tree directory, zaza.my_package.utilities would be your shared helper functions, not intended to be run by Zaza.
If you want to see examples of what the files listed above contain, a good place to look at is zaza.openstack.
