Hi,
Is it possible to rename bind9-k8s to designate-bind-k8s, not to clash with https://charmhub.io/bind-k8s, and differentiate its usage clearly ?
Hi,
Hi,
Do you mean updating the title on its charmhub page or are you looking to change the name of the charm itself?
Charms cannot be renamed but their charmhub page title can be updated by changing the display-name field in metadata.yaml.
Thanks,
Odysseus
I want to rename the charm, is the solution to register the charm to a new name and then delete the old one ?
