Hi @roadmr. Can you please remove charm registration for capsule and the old published charms from charm-k8s-capsule (before revision 10)?
Hi, this is done, both capsule and charm-k8s-capsule are gone.
- Daniel
Thanks @roadmr.
I just uploaded it again but with the same problem. The icon is not showed properly. Do you have any idea why this is not working?
We set the right image name (icon.svg
) and the right size.
Looks like your icon is corrupted/invalid.
Error domain 1 code 74 on line 1483 column 1 of data: EndTag: '</' not found
Actually if you inspect the .charm file (it’s just a .zip, uncompress it) and look at the icon with a text editor you’ll notice it’s HTML, not XML/SVG. Definitely needs fixing.
- Daniel
Thanks a lot I’ll try to fix it
Hi there,
It’s done.
Out of curiosity, why was the second deletion needed? trouble updating the icon on charmhub?
- Daniel
No, I had to rename the charm
