Removal of revisions with wrong base from maas-region charm 3.8/edge channel
Hello team,
I need your help with the following. We have decided that the 3.8/edge channel of the charm maas-region will offer charms only on 26.04 base. That was not the initial decision, and as a result, the channel contains also some revisions with 24.04 base.
Please help me remove these revisions as the Charmhub message is confusing the users.
Thanks, Stamatis
Hi Stamatis,
You should be able to unrelease the revision for 24.04 from 3.8/edge and release them to the wanted channels
Feel free to reach out if you have any questions
Cheers, Simon
Hi Simon,
I have a couple.
a) Running charmcraft revisions maas-region is providing me with a list of the last 100 revisions, marking with released the last released revisions of each of the open channels. Where can I see the older ones? How can I reveal more info about them? b) How can I unrelease the revisions with the problematic base 24.04 from channel 3.8/edge ? No such action exists in the CLI and the API is not documented. Where does Charmhub find the base information that displays to the user? Is it coming from the latest released revision of the channel? Or it is coming from any of the prior released revisions that had 24.04 base? If the former, just releasing a newer revision on 3.8/edge channel with only base 26.04 would make 24.04 disappear from the UI?
Thanks, Stamatis
