Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new release includes the following change:
- Provide the building charms functionality through the pack command.
We want to highlight that with this release we’re going out of beta! Now you will be able to install charmcraft just by doing:
sudo snap install charmcraft
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
