Charmcraft supports the development of operators using the Charmed Operator Framework. It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
This new release includes the following changes:
- Enhanced charm template generated by ‘init’ to use the new sidecar-pattern
Use Charmcraft to:
- Build your Charmed Operator into a charm for distribution
Happy charming!
