Charmcraft supports Kubernetes operator development.
This new release includes the following changes:
- Support for
oci-imageresources. - Improvements to the
initcommand, among others: links to docs, more robust base project, better docstrings and comments. - Alert if
README.mdnot included in a packed bundle (as it is required for deploying). - Produce a
manifest.yamlwith the building context of the charm or bundle. - Fix the handling of charms with dashes in the name when dealing with libraries.
Charmcraft enables collaboration between operator developers, and publication on Charmhub 1, home of the Open Operator Collection.
Use charmcraft to:
- Init a new charm file structure
- Build your operator into a charm for distribution
You can use charmcraft with operators written in any language but we recommend the Python Operator Framework on Github which is also on PyPI 1 for ease of development and collaboration.
Charmcraft and the Python Operator Framework extend the operator pattern beyond Kubernetes with universal operators that drive Linux and Windows apps. The universal operator pattern is very exciting for multi-cloud application management.
Happy charming!
