Rawfile LocalPV Documentation
Rawfile LocalPV
This Juju machine charm deploys a Container Storage Interface (CSI) plugin, enabling a Canonical Kubernetes cluster to use OpenEBS Rawfile LocalPV as a storage backend. Rawfile LocalPV allows for the creation and management of tiered storage pools, enabling flexible and optimized storage for your workloads. By leveraging node selectors and different storage classes managed by the Rawfile LocalPV charm, you can efficiently allocate storage based on data access patterns and performance requirements.
Deployment
This section provides a brief overview on deploying, configuring and integrating the rawfile-localpv charm for basic usage.
  • An existing Canonical Kubernetes cluster. See the Canonical Kubernetes charm installation guide for setup details.
Deploy multiple storage pools using rawfile-localpv
This example creates two rawfile-localpv applications with different configurations for storage tiers.
The fast tier targets nodes labeled storagePool=fast with storage mounted at /mnt/fast backed by high-performance disks.
The cold tier targets nodes labeled storagePool=cold with storage mounted at /mnt/cold for infrequently accessed data.
This deployment uses node selectors to schedule the CSI workloads on nodes with the required storage. You’ll need to label your nodes appropriately to ensure correct scheduling of workloads using persistent volumes. Check the k8s and k8s-worker charm configuration options for node labeling instructions.
Fast storage pool (fast-storage.yaml):
fast-localpv:
  namespace: fast
  storage-class-name: fast-sc
  node-selector: storagePool=fast
  node-storage-path: /mnt/fast
Cold storage pool (cold-storage.yaml):
cold-localpv:
  namespace: cold
  storage-class-name: cold-sc
  node-selector: storagePool=cold
  node-storage-path: /mnt/cold
Deploy both applications and integrate with the k8s application:
juju deploy rawfile-localpv fast-localpv --config ./fast-storage.yaml
juju integrate k8s fast-localpv
juju deploy rawfile-localpv cold-localpv --config ./cold-storage.yaml
juju integrate k8s cold-localpv
Monitor the installation progress by running the following command:
juju status --watch 1s
Validate the storage pools
To validate the storage pools, deploy a test pod that requests a persistent volume from the fast tier. Since these volumes are node-bound, include the same nodeSelector label to ensure the pod schedules on the correct node.
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
  storageClassName: fast-sc
apiVersion: v1
kind: Pod
metadata:
spec:
  nodeSelector:
    storagePool: fast
  containers:
    - name: writer
      image: busybox
      command: ["/bin/sh", "-c"]
      args:
        - echo "Hello!" > /data/fast.txt && sleep 3600
      volumeMounts:
        - name: data
          mountPath: /data
  volumes:
    - name: data
      persistentVolumeClaim:
        claimName: fast-pvc
To check if your PVC is bound, run:
kubectl get pvc fast-pvc -o jsonpath='{.status.phase}'
If everything is set up correctly, this command should return Bound, meaning the PVC has successfully attached to the provisioner.
Next, confirm that the pod has attached the volume by running:
kubectl get pod fast-pod
If the pod is running as expected, you’ll see output similar to:
NAME       READY   STATUS    RESTARTS   AGE
fast-pod   1/1     Running   0          2m47s
To test other storage pools, like the cold storage pool, just repeat these steps using the appropriate node selectors and storage classes for each pool.
Project and community
The rawfile-localpv charm is a member of the Ubuntu family. It’s an open-source project that warmly welcomes community projects, contributions, suggestions, fixes, and constructive feedback.
