Repository: GitHub - baycarbone/charm-rancher-integrator: operator for rancher-integrator Bugs / Issues: GitHub · Where software is built
Development Setup
To set up a local test environment with MicroK8s:
# Install MicroK8s
$ sudo snap install --classic microk8s
# Wait for MicroK8s to be ready
$ sudo microk8s status --wait-ready
# Enable features required by Juju controller & charm
$ sudo microk8s enable storage dns ingress rbac
# (Optional) Alias kubectl bundled with MicroK8s package
$ sudo snap alias microk8s.kubectl kubectl
# (Optional) Add current user to 'microk8s' group
# This avoid needing to use 'sudo' with the 'microk8s' command
$ sudo usermod -aG microk8s $(whoami)
# Activate the new group (in the current shell only)
# Log out and log back in to make the change system-wide
$ newgrp microk8s
# Install Charmcraft
$ sudo snap install charmcraft
# Install juju
$ sudo snap install --classic juju
# Bootstrap the Juju controller on MicroK8s
$ juju bootstrap microk8s micro
# Add a new model to Juju
$ juju add-model development
Build and Deploy Locally
# Clone the charm code
$ git clone https://github.com/baycarbone/charm-rancher-integrator && cd charm-rancher-integrator
# Build the charm package
$ charmcraft pack
# Deploy!
$ juju deploy ./rancher-integrator.charm --resource rancher-integrator-image=baycarbone/rancher-integrator:latest
# Set required config options
$ juju config rancher-integrator url=<rancher url>
$ juju config rancher-integrator bearer-token=<rancher api token>
$ juju config rancher-integrator cert-verify=<'True'|'False'>
# Elavate permisions in order for the charm to communicate with the Kubernetes API
$ juju trust rancher-integrator --scope=cluster
# Wait for the deployment to complete
$ watch -n1 --color juju status --color
# Execute actions using actions-v2 for a better UX e.g:
export JUJU_FEATURES=actions-v2
$ juju run rancher-integrator/0 register --format=yaml
$ juju run rancher-integrator/0 unregister --format=yaml
$ juju run rancher-integrator/0 register name=<name> --format=yaml
Config options
url: url of the existing Rancher platform against which registration will be performed.
bearer-token: bearer-token needed to access the Rancher api. For more information on retrieving such a token, please see rancher-api-keys.
(optional) cert-verify: toggles verification of the Rancher platform certificate. Setting this to ‘False’ is not recommended but can be useful for development purposes when using a self-signed certificate.
Actions
register
Request the rancher-integration application to register the Kubernetes cluster, then retrieve the import manifest and apply it on the Kubernetes cluster hosting the charm.
Note:
The register action takes an optionalnameparameter when a user defined cluster name within the Rancher platform is desired. If this parameter is not set, a randomly generated cluster name will be assigned and returned to the user.
unregister
Request the rancher-integration application to unregister the Kubernetes cluster, then delete the import manifest from the Kubernetes cluster hosting the charm.
Testing
# Create a virtual environemnt for the charm code
$ python3 -m venv venv
# Activate the venv
$ source ./venv/bin/activate
# Install dependencies
$ pip install -r requirements-dev.txt
# Run the tests
$ ./run_tests
