Background Hey, I am deploying 3 applications… a nodejs app, nginx, and certbot… via juju!
I created an AWS VPC, 2 subnets (1 public, 1 private) … a natgateway and internet gateway…
About 3 months or so back I successfully used this VPC via JAAS controller and model… to deploy a webapp, give it TLS certs via certbot… and everything was seemingly fine. had DNS too via route 53…
My issue now is… I wiped out the applications in preparation to test some new configs… same VPC same networking same spaces… same subnets… but when I deploy I am not reusing the same machines nor same elastic ip address…
The problem
why is it when I deploy… I get some public ipv4 address… but now I need to attach an elastic ip… so that can be associated with the route53 setup… or am I wrong and no elastic ip is needed?? if I attempt to hit the public ip given in juju… nothing happens or gets shown in browser
when I associate an elastic ip, juju agent never grabs that in the status… and in fact I no longer can SSH into the machine at all… even though I can just fine before the elastic ip is associated.
my-first-mahrio-dev JAAS aws/us-west-1 2.9.18 unsupported 11:23:58+01:00
App Version Status Scale Charm Store Channel Rev OS Message
certbot active 1 certbot local 8 ubuntu (update) certbot is associated with mahrio
mahrio active 1 mahrio local 13 ubuntu (website-relation-changed) finished change 10:21
nginx active 1 nginx local 9 ubuntu (update) NGINX is running 10:22
certbot/8* active idle 34 12.34.56.78 (update) certbot is associated with mahrio
mahrio/14* active idle 35 10.0.2.188 3000/tcp (website-relation-changed) finished change 10:21
nginx/9* active idle 34 12.34.56.78 80/tcp,443/tcp (update) NGINX is running 10:22
34 started 12.34.56.78 i-12345a bionic us-west-1b running
35 started 10.0.2.188 i-12345b bionic us-west-1b Start instance attempt 1
Here’s my bundle I had exported from the working env… with a few defaults pared backed… like channel (which was all stable and not needed)
series: bionic
applications:
certbot:
charm: /home/charms/certbot-charm
num_units: 1
to:
- "1"
bindings:
"": mahrio-dev-public
mahrio:
charm: /home/charms/mahrio-charm
num_units: 1
to:
- "2"
options:
git_deploy_private_key: |
-----BEGIN OPENSSH PRIVATE KEY-----
-----END OPENSSH PRIVATE KEY-----
mahrio_config: |
domain1.com
domain2.com
mongodb_connection_str: SOME_MONGO_STRING
bindings:
"": mahrio-dev-backend
nginx:
charm: /home/charms/nginx-charm
num_units: 1
to:
- "1"
bindings:
machines:
"1":
constraints: instance-type=t3.micro
"2":
constraints: instance-type=t3.small
relations:
- - mahrio:website
- nginx:website
- - certbot:website
- mahrio:website
And some other metadata
$juju spaces
Name Space ID Subnets
alpha 0
mahrio-dev-backend 1 10.0.2.0/24
252.2.0.0/16
mahrio-dev-public 2 10.0.1.0/24
252.1.0.0/16
$ juju subnets
subnets:
10.0.1.0/24:
type: ipv4
provider-id: subnet-123
provider-network-id: vpc-00001
status: in-use
space: mahrio-dev-public
zones:
- us-west-1b
10.0.2.0/24:
type: ipv4
provider-id: subnet-456
status: in-use
space: mahrio-dev-backend
zones:
- us-west-1b
252.1.0.0/16:
type: ipv4
provider-id: subnet-123-INFAN-10-0-1-0-24
status: in-use
zones:
- us-west-1b
252.2.0.0/16:
type: ipv4
provider-id: subnet-456-INFAN-10-0-2-0-24
status: in-use
zones:
- us-west-1b
Thanks for taking a look
