Hi all,
The recent beta 3.1 release introduces creating vms in lxd cloud, described in https://github.com/juju/juju/pull/15004 I would like to ask if there is any workaround or if you are plannning on allowing the option to change the instance id of a particular machine created in a bootstrapped lxd cloud? In the example one shows
Notice the `virt-type` is correctly set in mongo.
$ juju mongo juju:PRIMARY> db.instanceData.find() { "_id" : "c495559c-2c38-4072-866a-25fadc29c7bc:0", "machineid" : "0", "instanceid" : "juju-29c7bc-0", "display-na
How can I access the db?
Kind regards
Mateusz
