I use maas cloud in general, but the machines I am adding are lxc containers generated via lxc launch
e.g
lxc launch images:ubuntu/jammy/cloud juju-test -p container-vlan10 --target infra3 -c user.network-config="$(cat /home/mother/cloud-init-scripts/network-config-infra-container.yaml | sed -e 's/IP_ADDR_10/10.10.10.80/g;s/IP_ADDR_99/10.10.99.80/g;s/IP_GATEWAY/10.10.10.1/g')"
root@juju-client:~# juju status --relations
testing juju-maas-3-0-3 maas/default 3.0.3.1 unsupported 17:36:14Z
mysql-innodb-cluster 8.0.31 active 3 mysql-innodb-cluster latest/edge 37 no Unit is ready: Mode: R/W, Cluster is ONLINE and can tolerate up to ONE failure.
mysql-innodb-cluster/4* active idle 19 10.10.99.141 Unit is ready: Mode: R/W, Cluster is ONLINE and can tolerate up to ONE failure.
mysql-innodb-cluster/5 active idle 20 10.10.99.142 Unit is ready: Mode: R/O, Cluster is ONLINE and can tolerate up to ONE failure.
mysql-innodb-cluster/6 active idle 21 10.10.99.143 Unit is ready: Mode: R/O, Cluster is ONLINE and can tolerate up to ONE failure.
5 started 10.10.10.171 juju-k8s-1 ubuntu@22.04 default Deployed
19 started 10.10.99.141 manual:10.10.99.141 ubuntu@22.04 Manually provisioned machine
20 started 10.10.99.142 manual:10.10.99.142 ubuntu@22.04 Manually provisioned machine
21 started 10.10.99.143 manual:10.10.99.143 ubuntu@22.04 Manually provisioned machine
mysql-innodb-cluster:cluster mysql-innodb-cluster:cluster mysql-innodb-cluster peer
mysql-innodb-cluster:coordinator mysql-innodb-cluster:coordinator coordinator peer
root@juju-client:~# juju add-machine ssh:ubuntu@juju-test
The authenticity of host 'juju-test (240.11.13.171)' can't be established.
ECDSA key fingerprint is SHA256:cVZY0P27zdpJ6veqlyK2q4bvwFAKRiuknai6iE0c9ak.
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Failed to add the host to the list of known hosts (/root/.ssh/known_hosts).
created machine 22
testing juju-maas-3-0-3 maas/default 3.0.3.1 unsupported 17:41:56Z
22 started juju-test manual:juju-test ubuntu@22.04 Manually provisioned machine
root@juju-client:~#
An attempt to deploy mysql to that machine ends with following error in debug
File "/var/lib/juju/agents/unit-mysql-0/charm/lib/charms/mysql/v0/mysql.py", line 497, in configure_instance
self._run_mysqlsh_script("\n".join(configure_instance_command))
File "/var/lib/juju/agents/unit-mysql-0/charm/src/mysql_vm_helpers.py", line 184, in _run_mysqlsh_script
raise MySQLClientError(e.stderr)
charms.mysql.v0.mysql.MySQLClientError: b'Cannot set LC_ALL to locale en_US.UTF-8: No such file or directory\nConfiguring local MySQL instance listening at port 3306 for use in an InnoDB cluster...\n\nThis instance reports its own addressas \x1b[1mjuju-test:3306\x1b[0m\nClients and other cluster members will communicate with it through this address by default. If this is not correct, the report_host MySQL system variable should be changed.\n\x1b[31mERROR: \x1b[0mCannot use host \'juju-test\' for instance \'juju-test:3306\' because it resolves to an IP address (127.0.1.1) that does not match a real network interface, thus it is not supported. Change your system settings and/or set the MySQL server \'report_host\' variable to a hostname that resolves to a supported IP address.\nTraceback (most recent call last):\n File "<string>", line 1, in <module>\nRuntimeError: Dba.configure_instance: Invalid host/IP \'juju-test\' resolves to \'127.0.1.1\' which is not supported.\n\n'
