The Juju team is proud to release Pylibjuju 3.3.1.0!
Pylibjuju enables you to drive Juju from Python, easing operations from day 2 and beyond. It is a toolkit for adding automation to your projects. Pylibjuju enables you to manage your Juju controllers, models, applications and units.
This is a release of the Pylibjuju 3.x track, which is compatible with any Juju 3 controller up to 3.3.1 which is the latest stable Juju release.
How do I get it?
The best way to get your hands on this release of Pylibjuju is to use pypi:
pip install juju
What’s Changed
- Remove paramiko upper-bound by @gboutry in https://github.com/juju/python-libjuju/pull/1005
- Remove explicit passing of event_loop into tests by @cderici in https://github.com/juju/python-libjuju/pull/1006
- chore: remove the upper restrictions on the websockets dependency by @tonyandrewmeyer in chore: remove the upper restrictions on the websockets dependency by tonyandrewmeyer · Pull Request #1007 · juju/python-libjuju · GitHub
- Target ceiling version by @cderici in https://github.com/juju/python-libjuju/pull/1008
- Make it easier to run tests using
makeby @cderici in https://github.com/juju/python-libjuju/pull/1012 - Avoid installing signal handlers to the event loop by @cderici in Avoid installing signal handlers to the event loop by cderici · Pull Request #1014 · juju/python-libjuju · GitHub
- feat: remove app block until done by @yanksyoon in feat: remove app block until done by yanksyoon · Pull Request #1017 · juju/python-libjuju · GitHub
- feat: remove app timeout by @yanksyoon in https://github.com/juju/python-libjuju/pull/1018
- Forward port latest changes from 2.9 onto 3.x by @cderici in Forward port latest changes from 2.9 onto 3.x by cderici · Pull Request #1022 · juju/python-libjuju · GitHub
- Release 3.3.1.0 notes by @cderici in Release 3.3.1.0 notes by cderici · Pull Request #1024 · juju/python-libjuju · GitHub
New Contributors
- @gboutry made their first contribution in https://github.com/juju/python-libjuju/pull/1005
- @tonyandrewmeyer made their first contribution in chore: remove the upper restrictions on the websockets dependency by tonyandrewmeyer · Pull Request #1007 · juju/python-libjuju · GitHub
- @yanksyoon made their first contribution in feat: remove app block until done by yanksyoon · Pull Request #1017 · juju/python-libjuju · GitHub
Full Changelog: Comparing 3.3.0.0...3.3.1.0 · juju/python-libjuju · GitHub
Feedback Appreciated!
We encourage everyone to let us know how you’re using Pylibjuju. Please ask questions on on Discourse, send us a message on Twitter using the hashtag #jujucharms.
