Hi, I have a problem when relating multiple endpoints to one prometheus instance using cross-model.
Every charm has two endpoints that I need to relate to. First application I relate goes as expected and adds the targets to prometheus.yaml
After relating a second endpoint from a different model, one of the previous target get removed.
And this goes on for every relation I make after this. If I instead remove a relation, another one gets implemented instead. For example, after removing the last related target with IP 192.168.161.22, the other target with IP 192.168.161.25 comes back.
The application I try to relate is Polkadot (source).
Does anyone know why this happens? I don’t know if the problem is on Prometheus2 charm or on Polkadot (interface_prometheus).
We posted this bug issue a couple of months ago. Could it be related to that?
