Preferred storage error not available during bootstrap following Juju Microk8s docs
ERROR preferred storage “microk8s.io/hostpath” not available Seen this post with similar error but the solution there didn’t work for me. Maybe I can wait a day?? and try again???
cloudop@cloudoperator:~$ juju bootstrap microk8s --bootstrap-constraints cores=2 --constraints mem=4G con-juju --verbose --debug --agent-version="2.9.22"
02:53:05 INFO  juju.cmd supercommand.go:56 running juju [2.9.25 0 695d9bc09df0725a168df52707336bb6a3a92ff7 gc go1.17.6]
02:53:05 DEBUG juju.cmd supercommand.go:57   args: []string{"/snap/juju/18221/bin/juju", "bootstrap", "microk8s", "--bootstrap-constraints", "cores=2", "--constraints", "mem=4G", "con-juju", "--verbose", "--debug", "--agent-version=2.9.22"}
02:53:07 DEBUG juju.kubernetes.provider provider.go:140 opening model "add-cloud".
ERROR preferred storage "microk8s.io/hostpath" not available
ryzengrind@calm-fox:~$ microk8s enable storage; microk8s status --wait-ready
DEPRECIATION WARNING: 'storage' is deprecated and will soon be removed. Please use 'hostpath-storage' instead.
Enabling default storage class.
WARNING: Hostpath storage is not suitable for production environments.
deployment.apps/hostpath-provisioner created
storageclass.storage.k8s.io/microk8s-hostpath created
serviceaccount/microk8s-hostpath created
clusterrole.rbac.authorization.k8s.io/microk8s-hostpath created
clusterrolebinding.rbac.authorization.k8s.io/microk8s-hostpath created
Storage will be available soon.
microk8s is running
high-availability: yes
  datastore master nodes: 192.168.20.232:19001 192.168.20.225:19001 192.168.20.228:19001
  datastore standby nodes: none
addons:
  enabled:
    dns                  # CoreDNS
    ha-cluster           # Configure high availability on the current node
    helm3                # Helm 3 - Kubernetes package manager
    hostpath-storage     # Storage class; allocates storage from host directory
  disabled:
    dashboard            # The Kubernetes dashboard
    dashboard-ingress    # Ingress definition for Kubernetes dashboard
    helm                 # Helm 2 - the package manager for Kubernetes
    host-access          # Allow Pods connecting to Host services smoothly
    ingress              # Ingress controller for external access
    linkerd              # Linkerd is a service mesh for Kubernetes and other frameworks
    metallb              # Loadbalancer for your Kubernetes cluster
    metrics-server       # K8s Metrics Server for API access to service metrics
    openebs              # OpenEBS is the open-source storage solution for Kubernetes
    portainer            # Portainer UI for your Kubernetes cluster
    prometheus           # Prometheus operator for monitoring and logging
    rbac                 # Role-Based Access Control for authorisation
    registry             # Private image registry exposed on localhost:32000
    traefik              # traefik Ingress controller for external access
ryzengrind@calm-fox:~$ snap info microk8s
summary:   Kubernetes for workstations and appliances
publisher: Canonical✓
store-url: https://snapcraft.io/microk8s
contact:   https://github.com/ubuntu/microk8s
license:   unset
description: |
  MicroK8s is a small, fast, secure, single node Kubernetes that installs on
  just about any Linux box. Use it for offline development, prototyping,
  testing, or use it on a VM as a small, cheap, reliable k8s for CI/CD. It's
  also a great k8s for appliances - develop your IoT apps for k8s and deploy
  them to MicroK8s on your boxes.
commands:
  - microk8s.add-node
  - microk8s.cilium
  - microk8s.config
  - microk8s.ctr
  - microk8s.dashboard-proxy
  - microk8s.dbctl
  - microk8s.disable
  - microk8s.enable
  - microk8s.helm
  - microk8s.helm3
  - microk8s.inspect
  - microk8s.istioctl
  - microk8s.join
  - microk8s.juju
  - microk8s.kubectl
  - microk8s.leave
  - microk8s.linkerd
  - microk8s
  - microk8s.refresh-certs
  - microk8s.remove-node
  - microk8s.reset
  - microk8s.start
  - microk8s.status
  - microk8s.stop
services:
  microk8s.daemon-apiserver:            simple, enabled, inactive
  microk8s.daemon-apiserver-kicker:     simple, enabled, active
  microk8s.daemon-cluster-agent:        simple, enabled, active
  microk8s.daemon-containerd:           notify, enabled, active
  microk8s.daemon-control-plane-kicker: simple, enabled, inactive
  microk8s.daemon-controller-manager:   simple, enabled, inactive
  microk8s.daemon-etcd:                 simple, enabled, inactive
  microk8s.daemon-flanneld:             simple, enabled, inactive
  microk8s.daemon-k8s-dqlite:           simple, enabled, active
  microk8s.daemon-kubelet:              simple, enabled, inactive
  microk8s.daemon-kubelite:             simple, enabled, active
  microk8s.daemon-proxy:                simple, enabled, inactive
  microk8s.daemon-scheduler:            simple, enabled, inactive
  microk8s.daemon-traefik:              simple, enabled, inactive
snap-id:      EaXqgt1lyCaxKaQCU349mlodBkDCXRcg
tracking:     latest/beta
refresh-date: 5 days ago, at 04:39 UTC
channels:
  1.23/stable:      v1.23.3  2022-01-27 (2954) 192MB classic
  1.23/candidate:   v1.23.3  2022-01-27 (2954) 192MB classic
  1.23/beta:        v1.23.3  2022-01-27 (2954) 192MB classic
  1.23/edge:        v1.23.4  2022-02-23 (3024) 192MB classic
  latest/stable:    v1.23.3  2022-02-05 (2954) 192MB classic
  latest/candidate: v1.23.3  2022-01-27 (2955) 192MB classic
  latest/beta:      v1.23.3  2022-01-27 (2955) 192MB classic
  latest/edge:      v1.23.4  2022-03-09 (3043) 194MB classic
  1.22/stable:      v1.22.6  2022-02-06 (2952) 168MB classic
  1.22/candidate:   v1.22.6  2022-01-27 (2952) 168MB classic
  1.22/beta:        v1.22.6  2022-01-27 (2952) 168MB classic
  1.22/edge:        v1.22.7  2022-02-21 (3012) 168MB classic
  1.21/stable:      v1.21.9  2022-02-06 (2953) 167MB classic
  1.21/candidate:   v1.21.9  2022-01-27 (2953) 167MB classic
  1.21/beta:        v1.21.9  2022-01-27 (2953) 167MB classic
  1.21/edge:        v1.21.10 2022-02-21 (3013) 167MB classic
  1.20/stable:      v1.20.13 2021-12-08 (2762) 189MB classic
  1.20/candidate:   v1.20.13 2021-12-08 (2762) 189MB classic
  1.20/beta:        v1.20.13 2021-12-08 (2762) 189MB classic
  1.20/edge:        v1.20.14 2022-01-11 (2852) 185MB classic
  1.19/stable:      v1.19.15 2021-09-30 (2535) 184MB classic
  1.19/candidate:   v1.19.15 2021-09-29 (2535) 184MB classic
  1.19/beta:        v1.19.15 2021-09-29 (2535) 184MB classic
  1.19/edge:        v1.19.16 2022-01-07 (2823) 180MB classic
  1.18/stable:      v1.18.20 2021-07-18 (2272) 169MB classic
  1.18/candidate:   v1.18.20 2021-07-12 (2272) 169MB classic
  1.18/beta:        v1.18.20 2021-07-12 (2272) 169MB classic
  1.18/edge:        v1.18.20 2021-11-03 (2651) 169MB classic
  1.17/stable:      v1.17.17 2021-04-03 (1923) 149MB classic
  1.17/candidate:   v1.17.17 2021-04-03 (1923) 149MB classic
  1.17/beta:        v1.17.17 2021-04-03 (1923) 149MB classic
  1.17/edge:        v1.17.17 2021-01-13 (1923) 149MB classic
  1.16/stable:      v1.16.15 2020-09-11 (1672) 150MB classic
  1.16/candidate:   v1.16.15 2020-09-03 (1672) 150MB classic
  1.16/beta:        v1.16.15 2020-09-03 (1672) 150MB classic
  1.16/edge:        v1.16.15 2020-09-02 (1672) 150MB classic
  1.15/stable:      v1.15.11 2020-03-27 (1305) 144MB classic
  1.15/candidate:   v1.15.11 2020-03-27 (1305) 144MB classic
  1.15/beta:        v1.15.11 2020-03-27 (1305) 144MB classic
  1.15/edge:        v1.15.11 2020-03-26 (1305) 144MB classic
  1.14/stable:      v1.14.10 2019-12-20 (1121) 164MB classic
  1.14/candidate:   ↑
  1.14/beta:        ↑
  1.14/edge:        v1.14.10 2020-03-26 (1306) 164MB classic
  1.13/stable:      v1.13.6  2019-05-20  (580) 173MB classic
  1.13/candidate:   ↑
  1.13/beta:        ↑
  1.13/edge:        ↑
  1.12/stable:      v1.12.9  2019-06-07  (613) 197MB classic
  1.12/candidate:   ↑
  1.12/beta:        ↑
  1.12/edge:        ↑
  1.11/stable:      –
  1.11/candidate:   –
  1.11/beta:        –
  1.11/edge:        v1.11.1  2018-07-24  (138) 164MB classic
  1.10/stable:      –
  1.10/candidate:   –
  1.10/beta:        –
  1.10/edge:        v1.11.1  2018-07-24  (137) 164MB classic
installed:          v1.23.3             (2955) 192MB classic
cloudop@cloudoperator:~$ juju status
ERROR No controllers registered.
Please either create a new controller using "juju bootstrap" or connect to
another controller that you have been given access to using "juju register".
cloudop@cloudoperator:~$ juju debug-log
cloudop@cloudoperator:~$ juju clouds
Only clouds with registered credentials are shown.
There are more clouds, use --all to see them.
You can bootstrap a new controller using one of these clouds...
Cloud       Regions  Default    Type  Credentials  Source    Description
localhost   1        localhost  lxd   0            built-in  LXD Container Hypervisor
maas-cloud  1        default    maas  1            local     Metal As A Service
maas-mk8s   1        default    maas  1            local     Metal As A Service
microk8s    1        localhost  k8s   0            built-in  A Kubernetes Cluster
Any insight on how I can bootstrap a juju controller on my arm64 RPI cluster would be greatly appreciated.
cloudop@cloudoperator:~$ kubectl get storageclass
NAME                          PROVISIONER            RECLAIMPOLICY   VOLUMEBINDINGMODE   ALLOWVOLUMEEXPANSION   AGE
microk8s-hostpath (default)   microk8s.io/hostpath   Delete          Immediate           false                  26m
