Behavior-driven development (BDD) emerged from test-driven development (TDD) and is quite popular (python: pytest-bdd, behave; javascript: cucumber, jest; go: ginkgo; rust: cucumber; C++: Catch2; C#: SpecFlow; …).
BDD means writing tests in the form of a grokable story:
GIVEN some initial state
WHEN something particular happens
THEN there is a concrete measurable outcome
When you phrase your tests in the form of grokable stories, they tend to turn out short, succinct, readable and kind to your future-self.
Typically, when you go all-in with BDD, you end up creating plain-text *.feature files in Gherkin language that describe behavior, which you then tightly couple with matching decorators. For example:
Feature: showing off behave
Scenario: run a simple test
Given we have behave installed
When we implement a test
Then behave will test it for us!
from behave import *
@given('we have behave installed')
def step_impl(context):
pass
@when('we implement a test')
assert True is not False
@then('behave will test it for us!')
assert context.failed is False
This could be tedious for several reasons:
- Keeping the
*.featurefiles in line with the test files is duplication of effort. - Operator framework (OF) tests using harness involve a mutable state, which has implications on the structure of tests. This may conflict with a BDD framework’s constructs.
- The
scenario - given - when - thenhierarchy imposed by decorators is too strict and will not fit the need of all tests. - “Bending” our tests just to fit a framework’s constructs is probably bad practice.
- Tests are not transferable from one framework to another (i.e. would need to put effort into migrating from e.g.
behavetopytest-bdd). - Adding another tool for the entire team to learn and master means friction.
Introducing loose-BDD
Going all-in with BDD means friction, so as an alternative I recently started practicing “loose BDD” using Gherkin comments. For example:
def test_config_option_overrides_fqdn(self):
"""The config option for external url must override all other external urls."""
# GIVEN a charm with the fqdn as its external URL
self.assertEqual(self.get_url_cli_arg(), self.fqdn_url)
self.assertTrue(self.is_service_running())
# WHEN the web_external_url config option is set
external_url = "http://foo.bar:8080/path/to/alertmanager"
self.harness.update_config({"web_external_url": external_url})
# THEN it is used as the cli arg instead of the fqdn
self.assertEqual(self.get_url_cli_arg(), external_url)
# WHEN the web_external_url config option is cleared
self.harness.update_config(unset=["web_external_url"])
# THEN the cli arg is reverted to the fqdn
Advantages
This has several advantages:
- No new dependencies and no need to learn new tools.
- You retain maximum flexibility in structuring the tests. For example:
- “Scenario” could be a module, a test class or even a test method.
- You can do nested
when - thenif it fits your purpose. - etc.
- Reviewers can clearly see your intent. Mismatches between expected and actual behavior are easier to point out during code review or otherwise.
- All you need to do to understand the intent of the vast majority of tests is to read three lines of comments: given, when, then.
Disadvantages
However, loose Gherkin comments also have some disadvantages:
- The comments do not show up in error messages. But frankly, to debug test failures we would open the test anyway, and IDEs let you navigate to the line of failure in a matter of a click… where you will find the illuminating Gherkin comments.
- Need to foster a culture of tending to test comments. Ideally, tests are self-documenting, but in many cases with charm tests, they are not easy to understand. Gherkin comments help. A lot.
Conclusion
Considering the above, I currently believe that loose Gherkin comments are the better tradeoff.
