How to contribute
Overview
This document explains the processes and practices recommended for contributing enhancements to the Pollen operator.
- Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
- If you would like to chat with us about your use-cases or proposed implementation, you can reach us at Canonical Mattermost public channel or Discourse.
- Familiarising yourself with the Charmed Operator Framework library will help you a lot when working on new features or bug fixes.
- All enhancements require review before being merged. Code review typically examines
- code quality
- test coverage
- user experience for Juju operators of this charm.
- Please help us out in ensuring easy to review branches by rebasing your pull request branch onto the
mainbranch. This also avoids merge commits and creates a linear Git commit history. - Please generate src documentation for every commit. See the section below for more details.
Developing
The code for this charm can be downloaded as follows:
git clone https://github.com/canonical/pollen-operator
You can use the environments created by tox for development:
tox --notest -e unit
source .tox/unit/bin/activate
Testing
The following commands can then be used to run the tests:
tox: Runs all of the basic checks (lint,unit,static, andcoverage-report).tox -e fmt: Runs formatting usingblackandisort.tox -e lint: Runs a range of static code analysis to check the code.tox -e static: Runs other checks such asbanditfor security issues.tox -e unit: Runs the unit tests.tox -e integration: Runs the integration tests.
Generating src docs for every commit
Run the following command:
echo -e "tox -e src-docs\ngit add src-docs\n" >> .git/hooks/pre-commit
chmod +x .git/hooks/pre-commit
Build charm
Build the charm in this git repository using:
charmcraft pack
Deploy
# Create a model
juju add-model pollen-dev
# Enable DEBUG logging
juju model-config logging-config="<root>=INFO;unit=DEBUG"
# Deploy the charm (assuming you're on amd64)
juju deploy ./pollen_ubuntu-22.04-amd64.charm
Canonical Contributor Agreement
Canonical welcomes contributions to the Pollen Operator. Please check out our contributor agreement if you’re interested in contributing to the solution.
