Here’s the platform engineering’s pulse report #5 of 2025:
Github runner
- We are now using JIT tokens instead of registration tokens in the github-runner-operator project. Also some bug fixes related to reactive runners with JIT tokens.
Wordpress
- Add upload_max_filesize, post_max_size, and max_execution_time configuration to the wordpress-k8s charm.
Charmed-cloudflared
- Charmed-cloudflared snap has been upgraded to 2025.2.1 on latest/edge channel.
- Add a charm config charmed-cloudflared-snap-channel to select the charmed-cloudflared snap channel in cloudflared charm.
12-factor
- 12 Factor charms now supports SMTP integration.
Synapse
- Bug fix for how IRC Bridge handles Ingress events for the media proxy.
- Synapse charm uses a different repo for getting the synapse-invite-checker module.
- We started working on migrating from Mjolnir to Draupnir as the new Matrix moderation tool.
DNS
- Workflows and CI were optimized to work with the dns-operators monorepo
- The dns-policy-operator was added to the monorep
