Here is a recap of this pulse from Platform Engineering team.
Github Runner
- The GitHub Runner Image Builder has been updated so that it does not rebuild an image when an image relation changed event occurs. Instead, it reuses an existing image.
Wazuh
- A synchronous delivery process based on renovate has been configured for Wazuh and the settings repository
Gateway-api-integrator
- dns-record relation is now supported in gateway-api-integrator charm, although it treats the whole external hostname as a zone at the moment as a first solution
WordPress
- WordPress charm revision 144 released upgrading PHP version to 8.3 and WordPress version to 6.8.1.
HAproxy
- haproxy-operator now supports check_port, allowing charms to customize the port used for http-check
Documentation
- Vale style guide warnings have been resolved in the GitHub Runner Image Builder, Squid Proxy Htfile auth helper, Indico operator, Penpot operator, WordPress operator, Discourse operator, and HTTPRequest Lego Provider.
- How-to guides were added for the Penpot operator charm.
- The contributing documentation was updated for the Wazuh Server charm.
- An input has been added to operator workflows to make the Vale style guide check mandatory for success.
