PgBouncer revision 81
Thuesday, December 7, 2023
Dear community, this is to inform you that new PgBouncer is published in 1/stable charmhub channel for IAAS/VM.
The features you can start using today:
Bugfixes included:
- Juju Secrets fixes provided by updated data Interfaces library (LIBPATCH 24)
- Ported K8s fix for GitHub Issue #166 to VM charm [DPE-3113]
GitHub Releases provide a detailed list of bugfixes/PRs/commits for each revision.
What is inside the charms:
- Charmed PgBouncer ships the latest PgBouncer “1.21.0-0ubuntu0.22.04.1~ppa1”
- The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1”
- VM charms based on Charmed PostgreSQL SNAP (Ubuntu LTS “22.04” - ubuntu:22.04-based) (updated from the revision 85 to the revision 89)
- Principal charms support the latest LTS series “22.04” only
- Subordinate charms support LTS “22.04” and “20.04” only
Technical notes:
- Upgrade (
juju refresh) is possible from this revision 76+ - Please check the external components requirements
- Use this operator together with a modern operator “Charmed PostgreSQL”
How to reach us:
Contribute to the project!
