PgBouncer revision 77
Monday, October 23, 2023
Dear community, this is to inform you that new PgBouncer is published in 1/stable charmhub channel for IAAS/VM.
The features you can start using today:
- Add Juju 3 support (Juju 2 is still supported) [DPE-1761]
- Juju peer and relation secrets support [DPE-1765][DPE-2299]
- Charm minor upgrades and minor rollbacks [DPE-1770]
- “Charmed PostgreSQL” extensions support [DPE-2055]
- COS support [DPE-1778]
- Logs rotation [DPE-1757]
- The “data-integrator” support
- Support for modern
postgresql_client, legacypgsqlandtls-certificatesinterfaces - Workload updated to PgBouncer 1.18 (fixes for PostgreSQL 14)
- Complete documentation on CharmHub
Bugfixes included:
What is inside the charms:
- Charmed PgBouncer ships the latest PgBouncer “1.18.0-0ubuntu0.22.04.1”
- The Prometheus pgbouncer-exporter is “0.7.0-0ubuntu0.22.04.1~ppa1”
- VM charms based on Charmed PostgreSQL SNAP (Ubuntu LTS “22.04” - ubuntu:22.04-based)
Technical notes:
- Upgrade (
juju refresh) is possible from this revision 77+. - Please check the external components requirements
- Use this operator together with a modern operator “Charmed PostgreSQL”.
How to reach us:
Contribute to the project!
Footer:
It is the first stable release of the operator “PgBouncer” by Canonical Data.
Well done, Team!
