Tutorial
This section of our documentation contains a hands-on tutorial to help you learn how to deploy Charmed PgBouncer together with PostgreSQL on Kubernetes, and become familiar with some of its operations.
While this tutorial intends to guide you as you deploy Charmed PgBouncer K8s for the first time, it will be most beneficial if:
- You have some experience using a Linux-based CLI
- You are familiar with PgBouncer concepts such as load balancing and connection pooling.
- Your computer fulfils the minimum system requirements
Tutorial contents
This Charmed PgBouncer K8s tutorial has the following parts:
| Step | Details |
| 1. Set up the environment | Set up a cloud environment for your deployment using Multipass with MicroK8s and Juju. |
| 2. Deploy PgBouncer | Learn to deploy Charmed PgBouncer with Juju |
| 3. Manage your units | Learn how to scale PgBouncer units |
| 4. Enable security with TLS | Learn how to enable TLS encryption in PgBouncer traffic |
| 5. Clean up the environment | Free up your machine’s resources |
