PgBouncer K8s revision 103
March 8, 2024
Dear community, we are excited to announce that the new Charmed PgBouncer K8s operator is published in the 1/stable charmhub channel for Kubernetes.
New features
- Juju 3.1.7 support (changes to Juju secrets) (#196)
- Improved stability (DPE-3049| #186)
- Fewer restarts on deployments and integrations
- Updated Charmed PostgreSQL ROCK (revision 96)
- Updated Python library dependencies (#226)
Bugfixes
Canonical Data issues are now public on both Jira and GitHub platforms. GitHub Releases provide a detailed list of bugfixes/PRs/Git commits for each revision.
Highlights for the current revision
- Fix secret keys: do not set peer secrets as peer data (#212)
- Removed binary dependencies (DPE-3062 | #179)
- Fixed Juju secrets usage (DPE-3184 | #178)
- Updated TLS libraries (#191)
Inside the charms
- Charmed PgBouncer K8s ships the latest PgBouncer
1.21.0-0ubuntu0.22.04.1~ppa1 - The Prometheus pgbouncer-exporter is
0.7.0-0ubuntu0.22.04.1~ppa1 - K8s charms based on our ROCK OCI (Ubuntu LTS 22.04 -
ubuntu:22.04-based)
Technical notes
- Upgrade via
juju refreshis possible from this revision onwards (103+) - Please check the external components requirements
- Use this operator together with the Charmed PostgreSQL K8s operator
Contact
Open a GitHub issue if you want to submit a bug report, or contribute to the project!
Check our Contacts page for more ways to reach us.
