How to manage related applications
Modern postgresql_client interface:
Relations to new applications are supported via the “postgresql_client” interface. To create a relation:
juju integrate pgbouncer-k8s application
To remove a relation:
juju remove-relation pgbouncer-k8s application
All listed on CharmHub applications are available here, e.g.:
Legacy pgsql interface:
This charm also supports the legacy relation via the pgsql interface. Please note that these interface is deprecated.
juju relate pgbouncer-k8s:db myapplication-k8s
Also extended permissions can be requested using db-admin endpoint:
juju relate pgbouncer-k8s:db-admin myapplication-k8s
Internal operator user
To rotate the internal router passwords, the relation with backend-database should be removed and related again. That process will generate a new user and password for the application, while retaining the requested database and data.
juju remove-relation postgresql-k8s pgbouncer-k8s
juju integrate postgresql-k8s pgbouncer-k8s
