How to connect DB from outside of Kubernetes
To expose a Charmed PostgreSQL K8s database externally, this charm (PgBouncer K8s) should be deployed and related with the Charmed PostgreSQL K8s application. Charmed PgBouncer K8s then provides a configuration option expose-external (with options false, nodeport and loadbalancer) to control precisely how the database will be externally exposed.
By default (when expose-external=false), Charmed PgBouncer K8s creates a K8s service of type ClusterIP which it provides as endpoints to the related client applications. These endpoints are only accessible from within the K8s namespace (or juju model) where the PgBouncer K8s application is deployed.
Below is a juju model where PgBouncer K8s is related to PostgreSQL K8s and Data Integrator, which we will later use to demonstrate the configuration of expose-external:
$ juju status --relations
database uk8s-3-6-2 microk8s/localhost 3.6.2 unsupported 14:06:38Z
data-integrator active 1 data-integrator latest/stable 78 10.152.183.106 no
pgbouncer-k8s 1.21.0 active 1 pgbouncer-k8s 1/edge 406 10.152.183.170 no
postgresql-k8s 14.15 active 2 postgresql-k8s 14/edge 495 10.152.183.164 no
data-integrator/0* active idle 10.1.241.222
pgbouncer-k8s/0* active idle 10.1.241.211
postgresql-k8s/0 active idle 10.1.241.223
postgresql-k8s/1* active idle 10.1.241.251 Primary
data-integrator:data-integrator-peers data-integrator:data-integrator-peers data-integrator-peers peer
pgbouncer-k8s:database data-integrator:postgresql postgresql_client regular
pgbouncer-k8s:pgb-peers pgbouncer-k8s:pgb-peers pgb_peers peer
pgbouncer-k8s:upgrade pgbouncer-k8s:upgrade upgrade peer
postgresql-k8s:database pgbouncer-k8s:backend-database postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
When expose-external=false (default value), the following shows the endpoints returned to the client:
$ juju config pgbouncer-k8s expose-external=false
$ juju run data-integrator/0 get-credentials
- task 2 on unit-data-integrator-0
Waiting for task 2...
ok: "True"
postgresql:
data: '{"database": "test_database", "external-node-connectivity": "true", "requested-secrets":
"[\"username\", \"password\", \"tls\", \"tls-ca\", \"uris\"]"}'
database: test_database
endpoints: pgbouncer-k8s-service.database.svc.cluster.local:6432
password: fXw7lzSrHtRT8EUILPo4xfXA
read-only-endpoints: pgbouncer-k8s-service.database.svc.cluster.local:6432
uris: postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@pgbouncer-k8s-service.database.svc.cluster.local:6432/test_database
username: relation_id_6
version: "14.15"
The following shows a postgresql client connecting to the the provided endpoints from the data integrator unit (which is deployed in the same K8s namespace, i.e. the same juju model, as PgBouncer K8s):
root@data-integrator-0:/var/lib/juju# psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@pgbouncer-k8s-service.database.svc.cluster.local:6432/test_database
psql (14.15 (Ubuntu 14.15-0ubuntu0.22.04.1))
Type "help" for help.
test_database=> \l
List of databases
Name | Owner | Encoding | Collate | Ctype | Access privileges
pgbouncer | operator | UTF8 | C | C.UTF-8 | operator=CTc/operator +
| | | | | relation_id_7=CTc/operator +
| | | | | admin=CTc/operator +
| | | | | backup=CTc/operator +
| | | | | replication=CTc/operator +
| | | | | rewind=CTc/operator +
| | | | | monitoring=CTc/operator
postgres | operator | UTF8 | C | C.UTF-8 | operator=CTc/operator +
| | | | | monitoring=CTc/operator +
| | | | | admin=c/operator
template0 | operator | UTF8 | C | C.UTF-8 | =c/operator +
template1 | operator | UTF8 | C | C.UTF-8 | =c/operator +
test_database | relation_id_7 | UTF8 | C | C.UTF-8 | relation_id_7=CTc/relation_id_7+
| | | | | relation_id_6=CTc/relation_id_7+
| | | | | admin=CTc/relation_id_7
(5 rows)
test_database=> exit
root@data-integrator-0:/var/lib/juju# psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@pgbouncer-k8s-service.database.svc.cluster.local:6432/test_database_readonly
test_database_readonly=> \l
List of databases
| | | | | admin=c/operator
(5 rows)
External Access
PgBouncer K8s can be made externally accessible by setting expose-external=nodeport (corresponding to K8s NodePort service) or expose-external=loadbalancer (corresponding to K8s LoadBalancer service).
When expose-external=nodeport, PgBouncer K8s will provide as endpoints comma-separated node:port values of the nodes where the PgBouncer K8s units are scheduled.
$ juju config pgbouncer-k8s expose-external=nodeport
Running operation 3 with 1 task
- task 4 on unit-data-integrator-0
Waiting for task 4...
ok: "True"
postgresql:
endpoints: 10.0.0.44:31872
read-only-endpoints: 10.0.0.44:31872
uris: postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:31872/test_database
version: "14.15"
$ psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:31872/test_database
test_database=> \l
List of databases
| | | | | admin=c/operator
(5 rows)
$ psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:31872/test_database_readonly
List of databases
| | | | | admin=c/operator
(5 rows)
Similarly, when expose-external=loadbalancer, PgBouncer K8s will provide as endpoints comma-separated node:port values of the load balancer nodes associated with the PgBouncer K8s service:
$ juju config pgbouncer-k8s expose-external=loadbalancer
Running operation 5 with 1 task
- task 6 on unit-data-integrator-0
Waiting for task 6...
ok: "True"
postgresql:
endpoints: 10.0.0.44:6432
read-only-endpoints: 10.0.0.44:6432
uris: postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:6432/test_database
version: "14.15"
$ psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:6432/test_database
test_database=> \l
List of databases
| | | | | admin=c/operator
(5 rows)
Add the suffix _readonly to the database name to access read-only endpoints:
$ psql postgresql://relation_id_6:fXw7lzSrHtRT8EUILPo4xfXA@10.0.0.44:6432/test_database_readonly
List of databases
| | | | | admin=c/operator
(5 rows)
test_database_readonly=> create table test (id int);
ERROR: cannot execute CREATE TABLE in a read-only transaction
test_database_readonly=> exit
Note: The K8s service created by PgBouncer K8s is owned by the K8s StatefulSet that represents the PgBouncer K8s juju application. Thus, the K8s service is cleaned up when the PgBouncer K8s application is removed.
