The charm tech team has just released version 1.5.2 of the Operator Framework! This is a bug-fix release with the following patches:
- Fix harness model uuid to use the correct/current format used by juju (#782).
- Include the missing departing unit attribute on relation-departed events when using the harness (#790).
- Remove restrictive limits on the number and size of relation data items that can be set (#805).
- Fix type annotations that were causing failures in Ubuntu xenial based environments (#810).
Complaints can be filed as follows:
echo "<your-complaint>" >/dev/null
But really - if you run into any problems, please reach out to us here, on mattermost, or by filing a github issue.
