The Operator Framework team is proud to release version 1.3.0 of the Operator Framework!
OF 1.3.0 adds support for running one-shot commands via Pebble with the Container.exec method. This functionality uses the new Pebble “exec” API, which behaves similarly to lxd exec or kubectl exec – the Pebble CLI has a corresponding pebble exec command. The tool allows an operator to run a one-off command inside the workload container. It is very useful for troubleshooting, as well as performing maintenance tasks that haven’t yet been formalized as an action in a charm.
This release also includes a change to juju debug-code. The command now stops on all events and hooks, allowing charm authors to enter a debugging session without needing to specify a specific hook in advance. Charm authors can still access the old behavior by explicitly calling juju debug-code <app> --at <hook>.
OF 1.3.0 adds a mocked out filesystem to the testing harness. Charm authors can now attach and detach virtual storage, and read and write files to the test filesystem. This feature has been long requested, and allows for much more complete unit test coverage for charms.
Additionally, the charmed operator framework now exposes a “planned unit count,” to allow charms to handle HA config and similar features that require a peer count in advance of the peers actually coming online. The information supplied by this feature, comprising a single int that represents the number of peers (inclusive of the current unit) an application is expected to have, is intentionally minimalist. Charm authors should use this feature to save unnecessary execution of HA setup in an environment that doesn’t need it (or unnecessary non HA setup in an environment that does). Code paths using the feature should understand that the int can change, and that it does not include a guarantee that the units will be available. (If there is a deploy issue with a unit, for example, the planned unit count will not be reached until a human operator intervenes and resolves the issue.)
Beyond these highlights, 1.3.0 includes many minor features and bugfixes. A complete list follows:
Features:
- Include task logs in ChangeError.str (#653)
- Add support for storage to the testing harness.
- Add send_signal to pebble.Client and model.Container (#669)
- Add a test for restarting Pebble services on older Pebble versions (#658)
- Add storage details to storage events #
- Added support for One-shot commands #593
- Added “planned unit count” to model. #597
- Add support for the new wait-change API #595
- Let ‘debug-code’ catch all events by default #565
- Flatten nested dictionaries passed to action_set() #630
- Add pebble replan, support serverside restart. #580
- Added storage mappings to ContainerMeta as ContainerStorageMeta #601
- Remove ops.relation module #606 (Requires/Provides functionality now lives in a library.)
- Expose model uuid in ops.model.Model #563
- Expose ‘limit’ in RelationMeta and improve ‘scope’ #552
- Add user/group fields to Service (layer configuration) #540
- Add
__eq__to ops.pebble.Service so layer service equality can be checked (#592) - Send a list of services to stop to pebble in restart() instead (#591)
- Make Container.restart() semantics operate more like system services (#588)
- Various documentation and testing harness improvements.
- Streamlined build, test and release process.
Bugfixes:
- Adjust the ops.model.Resources.fetch method to throw a NameError (#661)
- Fix storage events with multiple hyphens #663
- Exec test fixes and “for line in process.stdout” fix (#655)
- Fixed issue with float to decimal conversion causing trouble with metrics. #609
- Fixed exception with very large log messages by splitting them #632
- Fix Pebble push() handling of binary files #574
- Fix Container.restart() accidentally operating on strings, add a testcase #590
- Various testing harness bugfixes.
