Hi Team,
I am facing the below SSL error. Any help on this?
HA setup with 3 controller node + 3 CEPH node + 20 compute noes
OpenStack version: Yoga
Host OS: Ubuntu 20.04
Juju version: 2.9.37
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [req-ab81de29-ccc4-4af5-851b-ae1ec48db6b0 0e42367c47734932b9a535a27314547e 75a4f053a6b6415898119a29debcfe76 - aca58c7f17af48ef8d7aef60764250dc aca58c7f17af48ef8d7aef60764250dc] [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] Failed to build and run instance: keystoneauth1.exceptions.connection.SSLError: SSL exception connecting to https://10.91.6.27:9696/v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55: HTTPSConnectionPool(host='10.91.6.27', port=9696): Max retries exceeded with url: /v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55 (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:2635)')))
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] Traceback (most recent call last):
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 665, in urlopen
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] httplib_response = self._make_request(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 421, in _make_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] six.raise_from(e, None)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "<string>", line 3, in raise_from
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 416, in _make_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] httplib_response = conn.getresponse()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3.8/http/client.py", line 1348, in getresponse
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] response.begin()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3.8/http/client.py", line 316, in begin
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] version, status, reason = self._read_status()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3.8/http/client.py", line 277, in _read_status
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3.8/socket.py", line 669, in readinto
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._sock.recv_into(b)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/green/ssl.py", line 252, in recv_into
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._base_recv(nbytes, flags, into=True, buffer_=buffer)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/green/ssl.py", line 267, in _base_recv
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] read = self.read(nbytes, buffer_)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/green/ssl.py", line 186, in read
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._call_trampolining(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/green/ssl.py", line 161, in _call_trampolining
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return func(*a, **kw)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3.8/ssl.py", line 1099, in read
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._sslobj.read(len, buffer)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] ssl.SSLEOFError: EOF occurred in violation of protocol (_ssl.c:2635)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] During handling of the above exception, another exception occurred:
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp = conn.urlopen(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 719, in urlopen
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] retries = retries.increment(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 436, in increment
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] raise MaxRetryError(_pool, url, error or ResponseError(cause))
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='10.91.6.27', port=9696): Max retries exceeded with url: /v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55 (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:2635)')))
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/keystoneauth1/session.py", line 1022, in _send_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp = self.session.request(method, url, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/requests/sessions.py", line 542, in request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp = self.send(prep, **send_kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/requests/sessions.py", line 655, in send
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] r = adapter.send(request, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/requests/adapters.py", line 514, in send
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] raise SSLError(e, request=request)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] requests.exceptions.SSLError: HTTPSConnectionPool(host='10.91.6.27', port=9696): Max retries exceeded with url: /v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55 (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:2635)')))
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/compute/manager.py", line 2503, in _build_and_run_instance
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] self.driver.spawn(context, instance, image_meta,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/virt/libvirt/driver.py", line 4329, in spawn
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] xml = self._get_guest_xml(context, instance, network_info,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/virt/libvirt/driver.py", line 7288, in _get_guest_xml
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] network_info_str = str(network_info)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/model.py", line 620, in __str__
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._sync_wrapper(fn, *args, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/model.py", line 603, in _sync_wrapper
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] self.wait()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/model.py", line 635, in wait
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] self[:] = self._gt.wait()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/greenthread.py", line 181, in wait
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._exit_event.wait()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/event.py", line 125, in wait
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] result = hub.switch()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/hubs/hub.py", line 313, in switch
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.greenlet.switch()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/eventlet/greenthread.py", line 221, in main
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] result = function(*args, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/utils.py", line 656, in context_wrapper
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return func(*args, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/compute/manager.py", line 1890, in _allocate_network_async
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] raise e
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/compute/manager.py", line 1868, in _allocate_network_async
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] nwinfo = self.network_api.allocate_for_instance(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/neutron.py", line 1215, in allocate_for_instance
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] created_port_ids = self._update_ports_for_instance(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/neutron.py", line 1357, in _update_ports_for_instance
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] vif.destroy()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/oslo_utils/excutils.py", line 227, in __exit__
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] self.force_reraise()
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/oslo_utils/excutils.py", line 200, in force_reraise
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] raise self.value
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/neutron.py", line 1326, in _update_ports_for_instance
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] updated_port = self._update_port(
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/neutron.py", line 582, in _update_port
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] port_response = port_client.update_port(port_id, port_req_body)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/nova/network/neutron.py", line 197, in wrapper
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] ret = obj(*args, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/v2_0/client.py", line 826, in update_port
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self._update_resource(self.port_path % (port), body=body,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/v2_0/client.py", line 2520, in _update_resource
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.put(path, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/v2_0/client.py", line 365, in put
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.retry_request("PUT", action, body=body,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/v2_0/client.py", line 333, in retry_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.do_request(method, action, body=body,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/v2_0/client.py", line 284, in do_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp, replybody = self.httpclient.do_request(action, method, body=body,
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/client.py", line 342, in do_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.request(url, method, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/neutronclient/client.py", line 330, in request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp = super(SessionClient, self).request(*args, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/keystoneauth1/adapter.py", line 257, in request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] return self.session.request(url, method, **kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/keystoneauth1/session.py", line 931, in request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] resp = send(**kwargs)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] File "/usr/lib/python3/dist-packages/keystoneauth1/session.py", line 1026, in _send_request
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] raise exceptions.SSLError(msg)
2023-05-11 05:48:28.703 89372 ERROR nova.compute.manager [instance: 53e8f644-d9b1-472a-9a01-f41f9e2f89b6] keystoneauth1.exceptions.connection.SSLError: SSL exception connecting to https://10.91.6.27:9696/v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55: HTTPSConnectionPool(host='10.91.6.27', port=9696): Max retries exceeded with url: /v2.0/ports/e8a5f31d-f560-476a-bbd3-1b8f6e428a55 (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:2635)')))
