As per this, they mention adding HORIZON_KEYSTONE_MULTIDOMAIN=‘TRUE’
to a local settings file.
Thus, I went ahead and created a new Python file under /var/snap/microstack/common/etc/horizon/local_settings.d
, namely _10_enable_multidomain_support.py
which only contains the aforementioned Horizon variable definition.
After restarting Horizon service via sudo snap restart microstack.horizon-uwsgi
, I can see the domain field in the login screen and also in the dropdown menu (at the navbar).
Given the above, you can now create a new domain, project and user and grant that user a role on that project.
e.g.
microstack.openstack domain create test-domain
microstack.openstack project create --domain test-domain demo
microstack.openstack user create --domain test-domain --password-prompt demo
microstack.openstack role add --project demo --user demo admin
To be able to see the “Identity > Domains” submenu, you need to assign your user the admin
role under a given domain, for example default
, as per this.
So something like this
openstack role add --domain default --user ADMIN_USER_ID admin
