This charm acts as a proxy to OpenStack and provides an interface to provide a set of credentials for a somewhat limited project user to the applications that are related to this charm.
Usage
When on OpenStack, this charm can be deployed, granted trust via Juju to access OpenStack, and then related to an application that supports the interface.
For example, Charmed Kubernetes has support for this, and can be deployed with the following bundle overlay (download it here ):
applications:
kubernetes-control-plane:
options:
allow-privileged: "true"
openstack-integrator:
annotations:
charm: openstack-integrator
num_units: 1
trust: true
openstack-cloud-controller:
charm: openstack-cloud-controller
cinder-csi:
charm: cinder-csi
relations:
- [openstack-cloud-controller:certificates, easyrsa:client]
- [openstack-cloud-controller:kube-control, kubernetes-control-plane:kube-control]
- [openstack-cloud-controller:external-cloud-provider, kubernetes-control-plane:external-cloud-provider]
- [openstack-cloud-controller:openstack, openstack-integrator:clients]
- [easyrsa:client, cinder-csi:certificates]
- [kubernetes-control-plane:kube-control, cinder-csi:kube-control]
- [openstack-integrator:clients, cinder-csi:openstack]
Using Juju 2.4 or later:
juju deploy charmed-kubernetes --overlay ./k8s-openstack-overlay.yaml --trust
To deploy with earlier versions of Juju, you will need to provide the cloud credentials via the credentials, charm config options.
Resource Usage Note
By relating to this charm, other charms can directly allocate resources, such as PersistentDisk volumes and Load Balancers, which could lead to cloud charges and count against quotas. Because these resources are not managed by Juju, they will not be automatically deleted when the models or applications are destroyed, nor will they show up in Juju’s status or GUI. It is therefore up to the operator to manually delete these resources when they are no longer needed, using the OpenStack console or API.
Examples
Following are some examples using OpenStack integration with Charmed Kubernetes.
Creating a pod with a PersistentDisk-backed volume
This script creates a busybox pod with a persistent volume claim backed by OpenStack’s PersistentDisk.
#!/bin/bash
# create a persistent volume claim using the StorageClass which is
# automatically created by cinder-csi when it is related to
# the openstack-integrator
kubectl create -f - <<EOY
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 100Mi
storageClassName: cinder-csi-default
EOY
# create the busybox pod with a volume using that PVC:
apiVersion: v1
kind: Pod
metadata:
namespace: default
spec:
containers:
- image: busybox
command:
- sleep
- "3600"
imagePullPolicy: IfNotPresent
volumeMounts:
- mountPath: "/pv"
restartPolicy: Always
volumes:
- name: testvolume
persistentVolumeClaim:
claimName: testclaim
EOY
Creating a service with a OpenStack load-balancer
The following script starts the hello-world pod behind a OpenStack-backed load-balancer.
kubectl create deployment hello-world --image=gcr.io/google-samples/node-hello:1.0
kubectl scale deployment hello-world --replicas=5
kubectl expose deployment hello-world --type=LoadBalancer --name=hello --port=8080
watch kubectl get svc hello -o wide
Project and community
openstack-integrator is a member of the Ubuntu family. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
Thinking about using Example Charm / Charm Bundle for your next project? Get in touch!
