Hi All ,
I just finish to deploy a Openstack Install following the Charm Deploy Guide ( https://docs.openstack.org/project-deploy-guide/charm-deployment-guide/2023.2/ ) and almost everything is working except the external network . I am familiar with Openvswitch and linuxbridge agent , but at this time I tried with OVN and now I can not access my first test instance .
Here my configuration :
root@juju-vm-01:~# juju status ovn-central
openstack maas-dc3-default maas-dc3/default 3.1.8 unsupported 18:17:10Z
neutron-api active 0 neutron-api 2023.2/stable 583 no Unit is ready
neutron-api-mysql-router 8.0.37 active 0 mysql-router 8.0/stable 189 no Unit is ready
neutron-api-plugin-ovn 23.1.0 active 0 neutron-api-plugin-ovn 2023.2/stable 113 no Unit is ready
ovn-central 22.09.1 active 3 ovn-central 23.09/stable 190 no Unit is ready
ovn-central/3* active idle 24 172.19.0.116 6641-6642/tcp Unit is ready
ovn-central/4 active idle 25 172.19.0.117 6641-6642/tcp Unit is ready (leader: ovnsb_db)
ovn-central/5 active idle 26 172.19.0.118 6641-6642/tcp Unit is ready (leader: ovnnb_db northd: active)
24 started 172.19.0.116 neutron-vm-01 ubuntu@22.04 default Deployed
25 started 172.19.0.117 neutron-vm-02 ubuntu@22.04 default Deployed
26 started 172.19.0.118 neutron-vm-03 ubuntu@22.04 default Deployed
root@juju-vm-01:~# juju status ovn-chassis
openstack maas-dc3-default maas-dc3/default 3.1.8 unsupported 18:18:00Z
ceph-osd active 0 ceph-osd reef/stable 577 no Unit is ready (1 OSD)
nova-compute 28.0.1 active 3 nova-compute 2023.2/stable 718 no Unit is ready
ovn-chassis 23.09.0 active 3 ovn-chassis 23.09/stable 233 no Unit is ready
nova-compute/7* active idle 10 172.19.0.14 Unit is ready
ovn-chassis/3* active idle 172.19.0.14 Unit is ready
nova-compute/8 active idle 12 172.19.0.13 Unit is ready
ovn-chassis/2 active idle 172.19.0.13 Unit is ready
nova-compute/9 active idle 13 172.19.0.12 Unit is ready
ovn-chassis/0 active idle 172.19.0.12 Unit is ready
10 started 172.19.0.14 srv-compute-04 ubuntu@22.04 default Deployed
12 started 172.19.0.13 srv-compute-03 ubuntu@22.04 default Deployed
13 started 172.19.0.12 srv-compute-02 ubuntu@22.04 default Deployed
I setup the ovn-chassi and ovn-central using that config file neutron.yaml
root@juju-vm-01:~# cat neutron.yaml
ovn-chassis:
bridge-interface-mappings: 'ovsbr2004:eno3.2004 ovsbr2000:eno2'
ovn-bridge-mappings: 'physnet1:ovsbr2004 physnet2:ovsbr2000'
neutron-api:
neutron-security-groups: true
flat-network-providers: "physnet1 physnet2"
debug: true
verbose: true
At Openstack everything is correctly setup include network and routers
root@juju-vm-01:~# openstack network list
| ID | Name | Subnets |
| 6fef2543-0480-428e-87b2-7ac006f5f507 | external_net | 23dbfd84-9997-44b9-9654-b02b7ae91e1e |
| d68ffd48-393a-4f66-82ff-1ce22a24e52a | INTERNAL_PROJECT_NET | 2fe9b422-919c-4f07-94a6-482647ff5e06 |
Here the external network created
root@juju-vm-01:~# openstack network show 6fef2543-0480-428e-87b2-7ac006f5f507
| Field | Value |
| admin_state_up | UP |
| availability_zone_hints | |
| availability_zones | |
| created_at | 2024-06-12T17:28:32Z |
| description | |
| dns_domain | None |
| id | 6fef2543-0480-428e-87b2-7ac006f5f507 |
| ipv4_address_scope | None |
| ipv6_address_scope | None |
| is_default | False |
| is_vlan_transparent | None |
| mtu | 1500 |
| name | external_net |
| port_security_enabled | False |
| project_id | d06e5e7d610d43b49ecfcefe9838c542 |
| provider:network_type | flat |
| provider:physical_network | physnet1 |
| provider:segmentation_id | None |
| qos_policy_id | None |
| revision_number | 6 |
| router:external | External |
| segments | None |
| shared | True |
| status | ACTIVE |
| subnets | 23dbfd84-9997-44b9-9654-b02b7ae91e1e |
| tags | |
| updated_at | 2024-06-13T14:10:18Z |
The router is correctly set
root@juju-vm-01:~# openstack router show 663e2602-19f2-46d6-b95e-2a0e07142723
| Field | Value |
| created_at | 2024-06-13T14:41:29Z |
| description | |
| external_gateway_info | {"network_id": "6fef2543-0480-428e-87b2-7ac006f5f507", "external_fixed_ips": [{"subnet_id": "23dbfd84-9997-44b9-9654-b02b7ae91e1e", "ip_address": "172.19.9.191"}], "enable_snat": true} |
| flavor_id | None |
| id | 663e2602-19f2-46d6-b95e-2a0e07142723 |
| interfaces_info | [{"port_id": "ac4d335b-5484-446f-909c-768d5325b09f", "ip_address": "192.168.89.1", "subnet_id": "2fe9b422-919c-4f07-94a6-482647ff5e06"}] |
| name | INTERNAL_PROJECT_ROUTER |
| project_id | b0eb806f31584b9d82374d5040c4f26b |
| revision_number | 4 |
| routes | |
| status | ACTIVE |
| tags | |
| updated_at | 2024-06-13T14:45:45Z |
I can’t even ping the router IP address at 172.19.9.191 . At the openvswitch-agent setup I used to troubleshooting it the ip netns at server where the router is running . With the OVN I was not able to find out where the it is running and also I was not able to see logs to identify it was created or not .
Any help on this ?
