OpenStack Charms 2024.1 (Caracal)
The 2024.1 (Caracal) release of the OpenStack Charms is now available. Please see the release notes for full details:
Highlights
- OpenStack 2024.1 (Caracal) is now supported on Ubuntu 22.04 LTS (via UCA).
- The manila charm has a new configuration option
scheduler-default-filters. This configures thescheduler_default_filtersparameter in manila configuration file. - Added support for Keystone audit middleware API logging
- The Ironic set of charms has gained OVN support
- Ironic: re-enable legacy RBAC
- gnocchi charm: add config to customize memcached heartbeat timeout
- glance-simplestreams-sync charm: make the GPG validation keyring configurable
- octavia charm: add config options for volume-based amphora
- manila charm: add support to configure scheduler default filters
- manila-netapp charm: add goodness-function config
- keystone-saml-mellon charm: improve compatibility with Chromium-based browsers
- keystone charm: disable cache by default
- keystone charm: add service role to service users
- ceilometer charm: add missing region setting in service_credentials
- nova-compute charm: make cloud-compute hostname same as nova.conf host
- openstack-dashboard charm: set X-Frame-Options header to sameorigin for https
- keystone-openidc charm: fix JSONDecodeError from misconfigured OIDCRedirectURI
- nova-compute charm: do not render console config for s390x
- manila-ganesha charm: use client cert for keystone-identity
- designate charm: stop apache2 when the unit is paused
- neutron-api charm: enable more recent DNS extensions (dns-integration-domain-keywords)
OpenStack Charms team
The OpenStack Charms team can be reached on the OpenStack Charms matrix channel and the Juju user forum.
Thank you
Lots of thanks to the below 58 contributors below who squashed bugs, enabled new features, and improved the documentation!
- Alan Baghumian
- Alex Kavanagh
- alitvinov
- Bartosz Woronicz
- Billy Olsen
- Brian Haley
- Carlos Bravo
- Chi Wai, Chan
- Chris MacNaughton
- Corey Bryant
- Danny Cocks
- David Negreira
- Edward Hope-Morley
- Erlon R. Cruz
- Fabian Fulga
- Facundo Ciccioli
- Federico Bosi
- Felipe Reyes
- Fulvio Galeazzi
- Gabriel Adrian Samfira
- Gabriel Cocenza
- Ionut Balutoiu
- Jadon Naas
- Jake Nabasny
- james lin
- James Page
- jneo8
- Jorge Merlino
- José Julián Espina
- Liam Young
- likui
- Luciano Lo Giudice
- Marcin Wilk
- Martin Kalcok
- Myles Penner
- Nicholas Njihia
- Nikolay Vinogradov
- Nobuto Murata
- Olivier Dufour-Cuvillier
- Pedro Castillo
- peppepetra86
- Peter Matulis
- Peter Sabaini
- Ponnuvel Palaniyappan
- Rodrigo Barbieri
- Samuel Allan
- Samuel Walladge
- Seyeong Kim
- Shunde Zhang
- Simon Dodsley
- Sohail Kazi
- Takashi Kajinami
- Trent Lloyd
- Utkarsh Bhatt
- utkarshbhatthere
- Vinit Chacharia
- Yoshi Kadokawa
- zhhuabj
