Hej,
Trying to do a clean/fresh Openstack deployment, based on the stable bundle found in the gitrepo (openstack-bundles/stable/openstack-base/bundle.yaml). The deployment seems to be stuck on Ceph-mon/[0,1].
ceph-mon/0 error idle 0/lxd/0 10.30.0.81 hook failed: "mon-relation-changed"
ceph-mon/1 error idle 1/lxd/0 10.30.0.82 hook failed: "mon-relation-changed"
ceph-mon/2* maintenance executing 2/lxd/0 10.30.0.67 Bootstrapping MON cluster
ceph-osd/0 waiting idle 0 10.30.0.63 Incomplete relation: monitor
ceph-osd/1 waiting idle 1 10.30.0.62 Incomplete relation: monitor
ceph-osd/2* waiting idle 2 10.30.0.64 Incomplete relation: monitor
ceph-radosgw/0* waiting idle 0/lxd/1 10.30.0.74 80/tcp Incomplete relations: mon
When I look at juju debug-log --include ceph-mon/0, I get this.
unit-ceph-mon-0: 17:29:07 INFO unit.ceph-mon/0.juju-log mon:0: Making dir /var/lib/ceph/mon/ceph-juju-a1b0c7-0-lxd-0 ceph:ceph 755
unit-ceph-mon-0: 17:29:07 DEBUG unit.ceph-mon/0.mon-relation-changed creating /var/lib/ceph/tmp/juju-a1b0c7-0-lxd-0.mon.keyring
unit-ceph-mon-0: 17:29:07 DEBUG unit.ceph-mon/0.mon-relation-changed added entity mon. auth(key=AQBv1TtjtNmVChAAbD2smDrDflB6OyBwf07tWQ==)
unit-ceph-mon-0: 17:29:07 DEBUG unit.ceph-mon/0.mon-relation-changed added 1 caps to entity mon.
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed Traceback (most recent call last):
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/hooks/mon-relation-changed", line 1362, in <module>
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed hooks.execute(sys.argv)
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/hooks/charmhelpers/core/hookenv.py", line 963, in execute
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed self._hooks[hook_name]()
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/hooks/mon-relation-changed", line 492, in mon_relation
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed if attempt_mon_cluster_bootstrap():
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/hooks/mon-relation-changed", line 504, in attempt_mon_cluster_bootstrap
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed ceph.bootstrap_monitor_cluster(leader_get('monitor-secret'))
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/lib/charms_ceph/utils.py", line 1331, in bootstrap_monitor_cluster
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed _create_monitor(keyring,
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/var/lib/juju/agents/unit-ceph-mon-0/charm/lib/charms_ceph/utils.py", line 1363, in _create_monitor
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed subprocess.check_call(['ceph-mon', '--mkfs',
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed raise CalledProcessError(retcode, cmd)
unit-ceph-mon-0: 17:29:08 WARNING unit.ceph-mon/0.mon-relation-changed subprocess.CalledProcessError: Command '['ceph-mon', '--mkfs', '-i', 'juju-a1b0c7-0-lxd-0', '--keyring', '/var/lib/ceph/tmp/juju-a1b0c7-0-lxd-0.mon.keyring']' died with <Signals.SIGILL: 4>.
unit-ceph-mon-0: 17:29:08 TRACE juju.worker.uniter.context checking for reboot request
unit-ceph-mon-0: 17:29:08 ERROR juju.worker.uniter.operation hook "mon-relation-changed" (via explicit, bespoke hook script) failed: exit status 1
unit-ceph-mon-0: 17:29:08 DEBUG juju.machinelock created rotating log file "/var/log/juju/machine-lock.log" with max size 10 MB and max backups 5
There seems to be something going bad with the execution of ceph-mon --mkfs …
I tried to execute that command manually on the ceph-mon/0 node, but it just replied with “Illegal instruction”.
The same applies to ceph-mon/1.
ceph-mon/2 seems to be fine, it is in “Waiting for quorum to be reached”.
Any idea whats wrong? Have I missed some requirement on the nodes?
BR/Patrik
