How to onboard an application with Charmed Hydra
This guide assumes that your application supports OAuth 2.0 and OpenID Connect (OIDC) protocols. If your application has not yet adopted these standards, you’ll first need to:
- Enable your application to make an authorization request to an OAuth Server.
- Implement a callback endpoint (
redirect_uri) that captures the authorization code received from the OAuth 2.0 Server (Hydra) and exchanges it for tokens.
To let your application authenticate with the Identity Platform, you must register it as an OAuth client in Hydra - the OAuth 2.0 and OIDC Server.
You can do this in one of two ways:
- integrate your charmed application with
oauthinterface - use the
create-oauth-clientJuju action provided by Charmed Hydra.
The preferred approach is to integrate your charmed application with Hydra through the
oauthinterface, which automatically manages client registration based on the provided configuration.
The Juju action and oauth interface offer the following parameters:
audience: A list of the audiences your client is allowed to request.grant-types: A list of allowed grant types. Default:["authorization_code"]redirect-uris: A list of your application’s callback URLs that Hydra is allowed to redirect to.response-types: A list of the allowed response types for the client. Default:["code"]scope: A list of scopes the client is allowed to request. Refer to this article for more information. Default:["openid", "profile", "email", "phone"]token-endpoint-auth-method: The authentication method the client is allowed to use at the token endpoint. One ofclient_secret_post,client_secret_basic,none(for public clients)client-secret: You can optionally provide a secret for your confidential client. If not provided, one will be autogenerated.
You can find detailed explanations of these parameters in the OIDC documentation.
Choosing the right grant type(s)
Depending on what your application does, you’ll need to choose one or more grant types:
- For human users interacting via browser-based flows, use the
authorization_codegrant type. - For machine-to-machine authentication and service accounts, use the
client_credentialsgrant type. - Devices with limited input (TVs, consoles, …) can leverage the
urn:ietf:params:oauth:grant-type:device_codegrant type to enable the device flow. - The
refresh_tokengrant type allows your app to get new access tokens without requiring the user to re-authenticate.
You can define multiple grant types for a single client by specifying them as a list (e.g. ["authorization_code", "refresh_token"]), allowing the client to support multiple OAuth flows.
Register your OAuth client
Once you know the right grant types and other parameters, run the create-oauth-client action:
juju run hydra/leader create-oauth-client \
grant-types='["authorization_code","refresh_token"]' \
redirect-uris='["https://your-app.example.com/callback"]' \
response-types='["code"]' \
scope='["openid","profile","email"]' \
token-endpoint-auth-method="client_secret_basic"
The action will return your new client’s ID and secret, which you can use to configure your application.
Update your OAuth client
If needed, you can update your client configuration by running:
juju run hydra/leader update-oauth-client \
client-id="your-client-id" \
client-secret="your-client-secret" \
Note that any parameters you omit will be reset to their default values.
Delete your OAuth client
You can delete your OAuth client with:
juju run hydra/leader delete-oauth-client \
