sysnasri
(Alireza Nasri)
12 March 2021 15:10
1
Hi, for a few months I have facing the following problem in charm deployments as rummer says my government is intercepting on TLS packets and thus the problem occurred since then.
so I want to know if there is another solution maybe offline install or something that bypass tls handshake.
I have already tested http/https proxy but does not work.
ubuntu@juju:~$ sudo juju deploy cs:~elasticsearch-charmers/bundle/elk-stack-3
ERROR cannot resolve charm URL “cs:~elasticsearch-charmers/bundle/elk-stack-3”: cannot get “/~elasticsearch-charmers/bundle/elk-stack-3/meta/any?include=id&include=supported-series&include=published”: Get “https://api.jujucharms.com/charmstore/v5/~elasticsearch-charmers/bundle/elk-stack-3/meta/any?include=id&include=supported-series&include=published ”: net/http: TLS handshake timeout
pedroleaoc
(Pedro Leão da Cruz)
12 March 2021 15:41
2
Hi Alireza, thanks for posting here
There’s a good article on deploying charms offline .
Let me know if that helps you - if not, we might be able to find another way.
sysnasri
(Alireza Nasri)
12 March 2021 17:33
3
May I say “God bless you”?
Thank you so much.
I was hopeless with the idea that I cannot deploy software.
pedroleaoc
12 March 2021 17:58
4
Of course you can, God bless you too!
Good luck and have fun with Juju. Let us know if you have anything else blocking you.
sysnasri
(Alireza Nasri)
12 March 2021 18:32
5
To be honest, I have had this question so far that could not handle it.
Would you please look at this topic
Guys, In my scenario which is deployed with maas and juju, I have a network 10.10.10.0/24 which is used to deploy openstack base churm bundle.
Also the maas and juju are within this network/subnet.
Recently I have added a new compute node to the cluster from a different network segment , 10.10.13.10/24
3 nova computes are in the same network segment but the newly added is from a different subnet.
External network uses flat type and my instances which are created in the new compute node are…
Or if possible someone from openstack charm look at that?
