Hi
I have created an Octavia load balancer. Its Provisioning Status is Active but Operating status is Offline. I tried both the ussuri/stable and yoga/stable versions but am facing the same issue. I need your help to fix this issue.
Octavia status:
root@staging-maas:~/cert# juju status octavia
openstack-staging maas-controller maas-one/default 2.9.49 unsupported 11:30:13+05:30
octavia 10.1.0 blocked 1 octavia ussuri/stable 282 no Virtual network for access to Amphorae is down
octavia-mysql-router 8.0.36 active 1 mysql-router 8.0/stable 154 no Unit is ready
octavia-ovn-chassis 22.03.3 active 1 ovn-chassis 22.03/stable 234 no Unit is ready
octavia/0* blocked idle 1/lxd/9 10.90.5.76 9876/tcp Virtual network for access to Amphorae is down
octavia-mysql-router/0* active idle 10.90.5.76 Unit is ready
octavia-ovn-chassis/0* active idle 10.90.5.76 Unit is ready
1 started 10.90.13.0 staging-controller-1 focal default Deployed
1/lxd/9 started 10.90.5.76 juju-f6bfb5-1-lxd-9 focal default Container started
o-hm0 interface status on Octavia/0
root@juju-f6bfb5-1-lxd-9:~# ifconfig o-hm0
o-hm0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.90.11.124 netmask 255.255.252.0 broadcast 10.90.11.255
inet6 fe80::202b:75ff:fe23:61f9 prefixlen 64 scopeid 0x20<link>
ether 22:2b:75:23:61:f9 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 71 bytes 7997 (7.9 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
