The Team
We are part of the Observability team, alongside Tracing and Service Mesh.
The Work
Loki persistence and networking
feat: Loki now persists its WAL and index directories, so data survives restarts: loki, loki (3.7 backport)
fix: Fixed the gRPC address the Loki compactor uses, and added the cluster service domain to the no-proxy list: loki, loki, loki (3.7 backport)
fix: Added the service hostname to the Loki certificate SANs: loki-k8s (3.7)
OpenTelemetry Collector configurability and compatibility
feat: Added a charm config option to disable individual Node Exporter collectors in the OpenTelemetry Collector: opentelemetry-collector, opentelemetry-collector (0.130 backport)
feat: Enabled multiple remote write workers in the OpenTelemetry Collector charm: opentelemetry-collector-k8s, opentelemetry-collector-k8s (0.130 backport)
feat: The OpenTelemetry Collector charm now starts its service before processing rules and dashboards, avoiding apparent outages with many relations: opentelemetry-collector-k8s (0.130)
fix: Fixed scrape job TLS handling so CA certificates given as ca or ca_file are written and tls_config is no longer dropped: opentelemetry-collector, opentelemetry-collector (0.130 backport)
fix: Fixed OpenTelemetry Collector support on ppc64le architecture: opentelemetry-collector, opentelemetry-collector (0.130 backport)
fix: Fixed Terraform channel variable validation for the OpenTelemetry Collector module: opentelemetry-collector (0.130)
COS documentation and release information
docs: Added a how-to guide on controlling metrics cardinality and documentation on running Loki on Juju: observability-stack, observability-stack
docs: Corrected the release checklist order and removed numbers from documentation headers: observability-stack, observability-stack
Other
feat: Added an ARM build for Tailscale Beacon: service-mesh
feat: Added the missing traces output for the OpenTelemetry Collector in the COS Terraform module, so traces can be sent to Tempo: observability-stack (3.0)
fix: Fixed the Alertmanager Catalogue item address by adding a trailing slash: alertmanager-k8s
Feedback welcome
As always, feedback is very welcome! Feel free to let us know your thoughts, questions, or suggestions either here or on our Matrix channel.
Thatβs all for this time! See you again in two weeks!
