Hi All, I need help on OpenStack nova-compute charm. It is blocked with “services not running that should be nova-api-metadata…”; It went in to blocked state once I configured OpenStack cluster environment for controllers with VIP.
How to fix this issue? and I seeing following logs inside nova-compute instance
nova-compute.log
An auth plguin is required to determine the endpoint URL
nova-api.log
DBNonExistentTable: (sqlite3.OperationalError) no such table: services
I don’t think we need to edit the nova.conf file for this and more over I also removed the relation after creating cluster environment and added back the relationship and that also didn’t helped me here.
When I deploy openstack-base-78,it was happend ,too.
nova-compute/0 blocked idle 0 10.0.0.159 Services not running that should be: nova-api-metadata, nova-compute
ntp/2 active idle 10.0.0.159 123/udp chrony: Ready
ovn-chassis/2 active idle 10.0.0.159 Unit is ready
nova-compute/1 blocked idle 1 10.0.0.157 Services not running that should be: nova-compute, nova-api-metadata
ntp/1 active idle 10.0.0.157 123/udp chrony: Ready
ovn-chassis/1 active idle 10.0.0.157 Unit is ready
nova-compute/2* blocked idle 2 10.0.0.158 Services not running that should be: nova-compute, nova-api-metadata
ntp/0* active idle 10.0.0.158 123/udp chrony: Ready
ovn-chassis/0* active idle 10.0.0.158 Unit is ready
If anyone in this thread is still experiencing trouble please file a bug. You will need to select a charm to file the bug against (‘Project’ dropdown). In this case it sounds like it should be OpenStack Nova Compute Charm.
