Nextcloud docs - installation
Installing the Juju distribution of Nextcloud is a simple process and takes about 20 minutes in a supported cloud.
You will need to prepare:
  • A domain name (I.e.g. nextcloud.example.com) - you need to sort this out with your DNS provider.
  • A SSL certificate private-key and fullchain in .pem format - this instruction takes you through the process.
*Note: The deployment of nextcloud can be fully automated by the use of juju charm bundles.
