Nextcloud docs - backup and restore
Essentially, the only backup needed of Nextcloud is the database and data which is covered by the respective charms used.
Database backup
Read in the Deploy Postgresql using Charmhub - The Open Operator Collection charm documentation on how to backup the database for Nextcloud as this is covered by that charm.
Primary storage/data
See the documentation for your selected primary storage charms.
Configuration
The nextcloud instances doesn’t need backups since they will be
identically setup as part of adding or removing units.
