We’ve wanted to have a way to inspect Juju units, and a new show-unit command now available in the 2.8.1 edge snap is designed to solve that problem.
Specifically, when debugging Juju deployments, it’s often useful to look at what’s in the relation data. There’s a way to do this using juju exec and hook commands, but it’s not very intuitive.
Hopefully this is useful.
Consider a simple example
$ juju deploy mariadb -n 3
$ juju deploy mediawiki
$ juju relate mediawiki:db mariadb
To look at the relation data bag for the db endpoint for a mediawiki unit, you’d need to do:
$ juju exec --unit mediawiki/0 -- 'relation-ids db'
db:1
$ juju exec --unit mediawiki/0 -- 'relation-list -r 1'
mariadb/0
mariadb/1
mariadb/2
$ juju exec --unit mediawiki/0 -- 'relation-get -r 1 - mariadb/2'
database: mediawiki
egress-subnets: 172.31.15.176/32
host: 172.31.15.176
ingress-address: 172.31.15.176
password: ahjuefumohxeich
private-address: 172.31.15.176
slave: "False"
user: avathuvoovienay
The relation-list command is not strictly needed if the model has reached steady state and units are all in scope.
The show-unit command does this and more - it surfaces what’s already displayed in status (–format yaml) as well as relation data for all related units, plus application data for the relation. You can filter on endpoint or related unit to see one thing at a time if desired.
$ juju show-unit mediawiki/0
mediawiki/0:
workload-version: 1.19.14
machine: "3"
opened-ports:
- 80/tcp
public-address: 13.210.206.157
charm: cs:mediawiki-19
leader: true
relation-info:
- endpoint: db
related-endpoint: db
application-data: {}
related-units:
mariadb/0:
in-scope: true
data:
database: mediawiki
egress-subnets: 172.31.9.118/32
host: 172.31.9.118
ingress-address: 172.31.9.118
password: ukacheovaiyahgo
private-address: 172.31.9.118
slave: "False"
user: querohpaepeipiu
mariadb/1:
in-scope: true
data:
database: mediawiki
egress-subnets: 172.31.31.116/32
host: 172.31.31.116
ingress-address: 172.31.31.116
password: eipuishaghahluu
private-address: 172.31.31.116
slave: "False"
user: fiebiudaiyeisho
mariadb/2:
in-scope: true
data:
database: mediawiki
host: 172.31.15.176
slave: "False"
Selecting just a single related unit to look at:
$ juju show-unit mediawiki/0 --related-unit mariadb/1
mediawiki/0:
machine: "3"
opened-ports:
- 80/tcp
leader: true
relation-info:
- endpoint: db
related-units:
mariadb/1:
in-scope: true
data:
database: mediawiki
host: 172.31.31.116
slave: "False"
Units will peer relations are handled:
$ juju show-unit mariadb/0 --endpoint cluster
mariadb/0:
workload-version: 10.1.40
machine: "0"
opened-ports: []
public-address: 13.210.96.137
charm: cs:trusty/mariadb-7
leader: true
relation-info:
- endpoint: cluster
related-endpoint: cluster
local-unit:
in-scope: true
data:
related-units:
mariadb/1:
in-scope: true
data:
mariadb/2:
in-scope: true
data:
