Charmcraft supports Kubernetes operator development.
This new release includes the following changes:
Added support for Charm Libraries, a mechanism to easily share and reuse charm interfaces and other components (check the tutorial: Creating and using charm libraries)
Initial support for charm bundles: the ‘pack’ command.
Better project bootstrapping in ‘init’: can be used in a non-empty directory and adds coverage to the project tests.
Charmcraft enables collaboration between operator developers, and publication on Charmhub 1, home of the Open Operator Collection.
Use charmcraft to:
- Init a new charm file structure
- Build your operator into a charm for distribution
You can use charmcraft with operators written in any language but we recommend the Python Operator Framework on Github which is also on PyPI 1 for ease of development and collaboration.
Charmcraft and the Python Operator Framework extend the operator pattern beyond Kubernetes with universal operators that drive Linux and Windows apps. The universal operator pattern is very exciting for multi-cloud application management.
Happy charming!
