When i install kubeflow
ops.pebble.ExecError: non-zero exit code 1 executing ['/usr/bin/mysqlsh', '--passwords-from-stdin', '--uri=serverconfig@katib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.:33062', '--python', '--verbose=0', '-c', "shell.options.set('useWizards', False)\nprint('###')\ncluster = dba.create_cluster('cluster-28203b3910d690dd5badc53a77b2d60e', {'communicationStack': 'MySQL'})\ncluster.set_instance_option('katib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.', 'label', 'katib-db-0')"], stdout="\x1b[1mPlease provide the password for 'serverconfig@katib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.:33062': \x1b[0m###\n+----------------------------------------+---------------+----------------+--------------------------------------------------+\n| Variable | Current Value | Required Value | Note |+----------------------------------------+---------------+----------------+--------------------------------------------------+\n| binlog_transaction_dependency_tracking | COMMIT_ORDER | WRITESET | Update the server variable || server_id | 1 | <unique ID> | Update read-only variable and restart the server |", stderr='Cannot set LC_ALL to locale en_US.UTF-8: No such file or directory\nA new InnoDB Cluster will be created on instance \'katib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.:3306\'.\n\nValidating instance configuration at katib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.:33062...\n\nThis instance reports its own address as \x1b[1mkatib-db-0.katib-db-endpoints.kubeflow.svc.cluster.local.:3306\x1b[0m\n\n\x1b[36mNOTE: \x1b[0mSome configuration options need to be fixed:\n\n\n\n+----------------------------------------+---------------+----------------+--------------------------------------------------+\n\nSome variables need to be changed, but cannot be done dynamically on the server.\n\x1b[36mNOTE: \x1b[0mPlease use the dba.configure_instance() command to repair these issues.\n\n\x1b[31mERROR: \x1b[0mInstance must be configured and validated with dba.check_instance_configuration() and dba.configure_instance() before it can be used in an InnoDB cluster.\nTraceback (most recent call last):\n File "<string>", line 3, in <module>\nRuntimeError: Dba.' [truncated]
microk8s config | juju add-k8s ml-k8s --client --storage=nfs-csi6
juju bootstrap ml-k8s ctlmk8s
juju add-model kubeflow
juju deploy kubeflow --trust --channel=1.10/stable
juju status
kubeflow ctlmk8s ml-k8s/localhost 3.6.9 unsupported 08:17:15+03:00
admission-webhook active 1 admission-webhook 1.10/stable 467 10.152.183.120 no
argo-controller active 1 argo-controller 3.5/stable 818 10.152.183.91 no
dex-auth active 1 dex-auth 2.41/stable 699 10.152.183.55 no
envoy active 1 envoy 2.4/stable 406 10.152.183.53 no
istio-ingressgateway active 1 istio-gateway 1.24/stable 1474 10.152.183.63 no
istio-pilot active 1 istio-pilot 1.24/stable 1417 10.152.183.175 no
jupyter-controller active 1 jupyter-controller 1.10/stable 1301 10.152.183.166 no
jupyter-ui active 1 jupyter-ui 1.10/stable 1222 10.152.183.116 no
katib-controller active 1 katib-controller 0.18/stable 1163 10.152.183.118 no
katib-db 8.0.41-0ubuntu0.22.04.1 maintenance 1 mysql-k8s 8.0/stable 255 10.152.183.245 no Starting mysqld
katib-db-manager waiting 1 katib-db-manager 0.18/stable 1123 10.152.183.219 no Incorrect/incomplete data found in relation relational-db. See logs
katib-ui active 1 katib-ui 0.18/stable 1122 10.152.183.229 no
kfp-api waiting 1 kfp-api 2.5/stable 2240 10.152.183.22 no Incorrect/incomplete data found in relation relational-db. See logs
kfp-db 8.0.41-0ubuntu0.22.04.1 maintenance 1 mysql-k8s 8.0/stable 255 10.152.183.117 no Starting mysqld
kfp-metadata-writer active 1 kfp-metadata-writer 2.5/stable 1310 10.152.183.30 no
kfp-persistence blocked 1 kfp-persistence 2.5/stable 2251 10.152.183.69 no [relation:kfp-api] Expected data from exactly 1 related applications - got 0.
kfp-profile-controller active 1 kfp-profile-controller 2.5/stable 2211 10.152.183.36 no
kfp-schedwf active 1 kfp-schedwf 2.5/stable 2261 10.152.183.26 no
kfp-ui blocked 1 kfp-ui 2.5/stable 2253 10.152.183.56 no [relation:kfp-api] Expected data from exactly 1 related applications - got 0.
kfp-viewer active 1 kfp-viewer 2.5/stable 2281 10.152.183.192 no
kfp-viz active 1 kfp-viz 2.5/stable 2197 10.152.183.222 no
knative-eventing active 1 knative-eventing 1.16/stable 866 10.152.183.160 no
knative-operator active 1 knative-operator 1.16/stable 827 10.152.183.77 no
knative-serving active 1 knative-serving 1.16/stable 865 10.152.183.237 no
kserve-controller active 1 kserve-controller 0.14/stable 951 10.152.183.24 no
kubeflow-dashboard active 1 kubeflow-dashboard 1.10/stable 847 10.152.183.234 no
kubeflow-profiles active 1 kubeflow-profiles 1.10/stable 643 10.152.183.203 no
kubeflow-roles active 1 kubeflow-roles 1.10/stable 357 10.152.183.216 no
kubeflow-volumes active 1 kubeflow-volumes 1.10/stable 514 10.152.183.235 no
metacontroller-operator active 1 metacontroller-operator 4.11/stable 510 10.152.183.248 no
minio res:oci-image@7f2474f active 1 minio ckf-1.10/stable 583 10.152.183.122 no
mlmd active 1 mlmd ckf-1.10/stable 344 10.152.183.182 no
oidc-gatekeeper active 1 oidc-gatekeeper ckf-1.10/stable 556 10.152.183.251 no
pvcviewer-operator active 1 pvcviewer-operator 1.10/stable 293 10.152.183.252 no
tensorboard-controller active 1 tensorboard-controller 1.10/stable 557 10.152.183.129 no
tensorboards-web-app active 1 tensorboards-web-app 1.10/stable 543 10.152.183.221 no
training-operator active 1 training-operator 1.9/stable 653 10.152.183.230 no
admission-webhook/0* active idle 10.1.149.1
argo-controller/0* active idle 10.1.149.2
dex-auth/0* active idle 10.1.149.6
envoy/0* active idle 10.1.149.36
istio-ingressgateway/0* active idle 10.1.149.61
istio-pilot/0* active idle 10.1.149.18
jupyter-controller/0* active idle 10.1.149.23
jupyter-ui/0* active idle 10.1.149.52
katib-controller/0* active idle 10.1.149.58
katib-db-manager/0* waiting idle 10.1.149.49 Incorrect/incomplete data found in relation relational-db. See logs
katib-db/0* maintenance executing 10.1.149.26 Starting mysqld
katib-ui/0* active idle 10.1.149.24
kfp-api/0* waiting idle 10.1.149.28 Incorrect/incomplete data found in relation relational-db. See logs
kfp-db/0* maintenance executing 10.1.149.20 Starting mysqld
kfp-metadata-writer/0* active idle 10.1.149.11
kfp-persistence/0* blocked idle 10.1.149.51 [relation:kfp-api] Expected data from exactly 1 related applications - got 0.
kfp-profile-controller/0* active idle 10.1.149.34
kfp-schedwf/0* active idle 10.1.149.21
kfp-ui/0* blocked idle 10.1.149.48 [relation:kfp-api] Expected data from exactly 1 related applications - got 0.
kfp-viewer/0* active idle 10.1.149.45
kfp-viz/0* active idle 10.1.149.31
knative-eventing/0* active idle 10.1.149.9
knative-operator/0* active idle 10.1.149.39
knative-serving/0* active idle 10.1.149.38
kserve-controller/0* active idle 10.1.149.4
kubeflow-dashboard/0* active idle 10.1.149.46
kubeflow-profiles/0* active idle 10.1.149.41
kubeflow-roles/0* active idle 10.1.149.10
kubeflow-volumes/0* active idle 10.1.149.43
metacontroller-operator/0* active idle 10.1.149.7
minio/0* active idle 10.1.149.8 9000-9001/TCP
mlmd/0* active idle 10.1.149.32
oidc-gatekeeper/0* active idle 10.1.149.60
pvcviewer-operator/0* active idle 10.1.149.54
tensorboard-controller/0* active idle 10.1.149.12
tensorboards-web-app/0* active idle 10.1.149.27
training-operator/0* active idle 10.1.149.62
administrator@dtc1-ml4-n01:~$ microk8s version
MicroK8s v1.32.9 revision 8511
administrator@dtc1-ml4-n01:~$ juju version
3.6.9-genericlinux-amd64
