diff-bundle
is a model command to show differences between a bundle and a model. This is really useful when you’re trying to see what changes might have been made in production over time that are different from the original bundle you started out with. You might also use this to snapshot updates to the bundle over time, especially if it’s in active development.
juju diff-bundle <bundle>
--overlay <overlay-file>
--map-machines <mapping or existing>
--annotations
Some usage examples:
juju diff-bundle localbundle.yaml
juju diff-bundle canonical-kubernetes
juju diff-bundle -m othermodel hadoop-spark
juju diff-bundle mongodb-cluster --channel beta
juju diff-bundle canonical-kubernetes --overlay local-config.yaml --overlay extra.yaml
juju diff-bundle localbundle.yaml --map-machines 3=4
This will compare the bundle (combined with any overlays) to the model, using the machine mapping provided, and display differences, considering (as a first pass):
- applications (missing or unexpected)
- unit counts (will need special handling for subordinates, where the bundle unit count will be zero)
- charm
- config
- series
- constraints
- annotations (if the
--annotations
flag is specified - these are likely to be noisy) - exposedness
In subsequent passes we’ll also diff placement, endpoint bindings and devices.
Here’s an example of diff-bundle output:
applications:
etcd:
num_units:
bundle: 3
model: 5
kubernetes-master:
charm:
bundle: cs:~containers/kubernetes-master-150
model: cs:~containers/kubernetes-master-144
constraints:
bundle: cores=2 mem=4G root-disk=16G
model: cores=2 mem=4G root-disk=8G
options:
channel:
bundle: 1.11/stable
model: 1.11/beta
other_option:
bundle: value
model:
kubeapi-load-balancer:
missing: model
machines:
"0":
series:
bundle: xenial
model: bionic
"1":
missing: bundle
relations:
bundle-additions:
- - kubernetes-master:kube-api-endpoint
- kubeapi-load-balancer:apiserver
- - etcd:certificates
- easyrsa:client
model-additions:
- - flannel:etcd
- etcd:db
